bideshm
Is there any Coating Thickness Measurement Sensor? |
Posted: Wed Sep 16, 2009 8:02 am |
Hi All,
I know that this topic should not be discussed here but I have been searching Google for last two days finding out a coating thickness measurement sensor only. I am sorry again.
I Would you like let you know that I am looking for a coating thickness measurement sensor for ferrous and non-ferrous substances (like other sensor such as temp, pressure etc) which would be connected to my micro controller board. The board will direct the sensor for data reading and eventually communicate the data to a connected PC through serial port.
I got numerous OEM device which reads the coating thickness and using their software only communicate to PC through RS232 interface. The problem is the application software works in a predefined manner.
I want to write an application software if possible the firmware too for reading the coating thickness on ferrous and non-ferrous substance.
I would like to know that;
A) Is there any product/device with coating thickness measurement sensor which has RS232 interface?
B) Can I see the value of the reading at real time using windows HyperTerm software?
C) Is there only the coating thickness measurement sensor available without total solution?
Thanks for your time and reply in advance.
Regards,
BideshM _________________ Bidesh Mukherjee
Software Engineer
Kolkata |
gomond
Posted: Thu Sep 17, 2009 3:39 pm |
BideshM
My background is mechanical and electronic engineering so I come across these issues all the time.
What is your requirement in more detail?
If you just want to measure the thickness prior to coating Vs after coating then you just purchase a cheap digital micrometer with serial output connector.
Then you can interface this to your PIC serial port.
Most cheap Chinese ones these days have it as an undocumented feature and you just look for a strange small cover that slides off with a series of contacts inside.
Or better still buy one with a documented interface.
Otherwise Peperl & Fuchs, Sick or many others have very sensitive ultrasonic distance sensors that may do the job.
Or just fabricate your own using a strain gauge and a spring loaded plunger.
There are many lateral approaches to solving this issue, it just requires a firm understanding of how you want it measured.
Cheers
Greg. |
SherpaDoug
Posted: Thu Sep 17, 2009 8:00 pm |
In ship inspections we measure paint thickness on steel with an inductive probe made by Fischer. It is quite expensive and the serial interface is a real pain. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Thu Sep 17, 2009 9:20 pm |
SherpaDoug,
Just out of curiousity, on what principal does the paint thickness probe operate? Is it acoustic, or RF based, or something else? What is it really measuring?
Tom |
FvM
Posted: Fri Sep 18, 2009 12:10 am |
Most popular techniques are inductive proxmity and ultrasonic sensors. You'll find a huge amount of information under "coating thickness measurement" on the internet. |
bideshm
RE:Is there any Coating Thickness Measurement Sensor? |
Posted: Wed Sep 23, 2009 5:11 am |
Hi All,
I want to measure coating thickness of chromium electroplating using any digital coating thickness gauge and then want to transmit the data to a PC for logging purpose. The data transmission can be done using RS232 interface to PC which most of this devices has.
I have got one of this device in my place. Please refer to the below link
http://www.flickr.com/photos/29743108@N00/3946756937/
What I would like to know whether these kind of devices have any standard format of data transmission?
The device I have selected "Metrix COAT MEASURER~P" has its own PC application software. I want to write the PC application software by myself rather than using supplied software with the device.
I would also like to know whether these kind of devices have any standard baud rate for serial data transmission over COM port?
Thanking You,
Bidesh |
FvM
Posted: Wed Sep 23, 2009 6:00 am |
Quote: | whether these kind of devices have any standard baud rate | Most likely.
Quote: | whether these kind of devices have any standard format of data transmission | I won't expect a standard. An industrial instrument should use a documented format in my opinion. Ask the manufacturer or distributor. At least, it's unlikely that they use encryption. You should be able to figure out the data format. |
bideshm
Posted: Wed Sep 23, 2009 7:11 am |
Hi FvM,
Thanks for your reply.
There is no soft copy of the manual for the device. When I purchase the device I will get the manual as hard copy format.
Maybe there I can find some more information regarding baud rate and transmitted data format.
If I face any problem reading the data, I would like to ask you again.
Thanking You, _________________ Bidesh Mukherjee
Software Engineer
Kolkata |
gomond
Possble option. |
Posted: Wed Sep 23, 2009 2:38 pm |
Hi bideshm
I am just leaving for work but I read your latest message.
Please have a look at:
http://www.migatron.com/products/rps-412a-v-1/index.htm
This sensor has similar characteristics as the one used on the instrument that you have shown.
Cheers Greg |
