pls help in coding multiplex 4 seven segment
j3p0y
PostPosted: Mon Sep 07, 2009 1:31 pm     Reply with quote
Pls help me to learn basic coding of multiplexing 4 seven segment display using pic16f877a. Because we have a project in programming a digital clock and my problem is I am running out of ports and I don't know how will I start the program in C language using multiplexing. I already have a circuit but I don't know how will I manipulate it. What should I do first?
Is there any website that I could learn it?
PostPosted: Mon Sep 07, 2009 1:50 pm     Reply with quote
Post a link to the data sheet for your 7-segment display.
Also see this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=39731
bungee-
PostPosted: Mon Sep 07, 2009 1:51 pm     Reply with quote
Try THIS link Wink
j3p0y
PostPosted: Wed Sep 09, 2009 2:33 am     Reply with quote
I also check the forum but the info is a bit confusing for multiplexing and there's is a lot of sites I visit but they use assembly language.
I don't know if there is a datasheet for the seven segment I bought but it has a label, "ARK SM451006k" and the size is 1 inch. Is there any pattern or guidelines in multiplexing coding? Pls help. Thanks!!
PostPosted: Wed Sep 09, 2009 12:39 pm     Reply with quote
Post a link to the webpage for it.
PostPosted: Thu Sep 10, 2009 10:54 am     Reply with quote
i tried to search in the website but it doesnt have any datasheet available for my 7 segment..but i used in my circuit is 300ohms resistor in each LED..
piripic
PostPosted: Thu Sep 10, 2009 12:40 pm     Reply with quote
Hi, maybe this can help you (look at the first post in this thread)
http://www.ccsinfo.com/forum/viewtopic.php?t=33495
