pls help in coding multiplex 4 seven segment
Posted: Mon Sep 07, 2009 1:31 pm
Pls help me to learn basic coding of multiplexing 4 seven segment display using pic16f877a. Because we have a project in programming a digital clock and my problem is I am running out of ports and I don't know how will I start the program in C language using multiplexing. I already have a circuit but I don't know how will I manipulate it. What should I do first?
Is there any website that I could learn it?
Posted: Mon Sep 07, 2009 1:50 pm
Post a link to the data sheet for your 7-segment display.
Posted: Wed Sep 09, 2009 2:33 am
I also check the forum but the info is a bit confusing for multiplexing and there's is a lot of sites I visit but they use assembly language.
I don't know if there is a datasheet for the seven segment I bought but it has a label, "ARK SM451006k" and the size is 1 inch. Is there any pattern or guidelines in multiplexing coding? Pls help. Thanks!!
Posted: Wed Sep 09, 2009 12:39 pm
Post a link to the webpage for it.
Posted: Thu Sep 10, 2009 10:54 am
i tried to search in the website but it doesnt have any datasheet available for my 7 segment..but i used in my circuit is 300ohms resistor in each LED..
