amith.srivatsa
Problems in code, changing from PIC16F690 to PIC16F876A |
Posted: Wed Sep 09, 2009 5:47 am |
Dear all,
I just changed from PIC16f690 to PIC16F876A. The PIC is used for motor driver application and it sends PWM to the H-bridge VNH2SP30. The code written for PIC16f690 worked well with no errors.
But now, I am getting some errors, mainly unknown keyword, unknown identifier when I try to compile the same code but this time for PIC16F876A. I just have changed the header files. Can anyone help me in debugging these errors ?
The error messages:
1.
Quote: |
Unknown keyword in #FUSES "INTRC_IO"
Unknown keyword in #FUSES "MCLR"
Unknown keyword in #FUSES "IESO"
Unknown keyword in #FUSES "FCMEN"
2.
Quote: |
Undefined identifier VSS_VDD
Undefined identifier setup_oscillator
Undefined identifier CCP_PWM_H_H
Would appreciate your help a lot, Many thanks in advance...
The code is below:
Sample - To test: Send via i2c to address 0x50 this data--> 0x02107F in order to set the motors to "Forward" & Half speed.
Setup: pin A5: serial communication
pin C0,C1: INA and INB for Motor1 (left)
pin C6,C7: INA and INB for Motor2 (right)
pin C2,C3: PWM for motor 1 & 2 respectively (speed control)
pinB4,B6: I2C communication, SDA & SCL
History:
Version 2:
-Automatic Stop after 600 ms function to stop motors when no i2c command has been send
still problems with prescale and div value but is working
Version 1:
- To control speed and direction of two DC motors using two Full H-Bridge VNH2SP30 and a PIC
#include <16F876A.h>
#device adc=8
#use delay(clock=8000000)
#use rs232(baud=19200, xmit=PIN_A5 ) // used for the serial com
#use i2c(Slave, sda=PIN_B4, scl=PIN_B6 )// used for i2c
Pin defines
#define led PIN_A4
#define driver_a PIN_C0 //INA and INB for motor1
#define driver_b PIN_C1
#define driver_c PIN_C6 //INA and INB for motor2
#define driver_d PIN_C7
#define TYPE 0x01
#define VERSION "V1.4"
#define VERSION_MAJOR 1
#define VERSION_MINOR 4
#define GET_TYPE 0x00
#define GET_VERSION 0x01
#define SET_MOTOR 0x02
Variables
int8 address;
int8 state;
int1 dataready = false;
int1 counting = false;
long int timerone = 0;
int overflow = 0;
int8 mode = 0;
int8 databyte1 = 0;
int8 databyte2 = 0;
Function prototypes
// description: This funtion enables or disables INA,INB imputs for both VNH2SP30 Full-bridges.
// arguments: Boolean enable
// return: None
void EnableDrivers( int1 enable );
// description: This funtion sets pwm according to the speed and INA, INB according to command for both motors
// arguments: int8 config
// int8 duty
// return: None
void SetDCControl( int8 config, int8 duty );
// There are some issues with the PWM module, before changing pinout please clear.
void clear( void );
// describtion: this function reads the address
// arguments: none
// return : the full adress ( 8bit wise)
int8 ReadAddress ( void );
// describtion: this function is used to process received data from the I2C bus.
// arguments: recieved byte 1 and received byte 2
// return : none
void ProcessData( int8 byte1, int8 byte2 );
// Interrupt service routine for i2c activty
#int_SSP
void SSP_isr(){
output_high(led);
// you will only be interrupted if the address is correct.
// first check the mode: read or write
state = i2c_isr_state();
if(state < 0x80){ //Master is sending data
if(state == 0){}
else if(state == 1)
mode = i2c_read();
else if(state == 2)
databyte1 = i2c_read();
else if(state == 3)
databyte2 = i2c_read();
if( mode == SET_MOTOR)
dataready = true;
else if( state == 0x80 ) // master is reading data
if( mode == GET_TYPE )
i2c_write( TYPE );
else if( mode == GET_VERSION)
i2c_write( VERSION_MAJOR );
else if( state == 0x81 ) // master is reading data
i2c_write( VERSION_MINOR );
output_low(led);
return;
void main(){
setup_adc(ADC_OFF);
//setup_timer_1(T1_DISABLED);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);//timer1 for automatic stop after 600ms function
setup_timer_2(T2_DIV_BY_16, 124, 1); // 1000 Hz, the pwm frequency
enable_interrupts(INT_SSP);
setup_oscillator(OSC_8MHZ);
printf("I2C motor driver with I2C\n\r");//print to serial
printf("Version %s\n\r", VERSION);
printf("Made by ROBODOMUS \n\r");
EnableDrivers( false );//True --> INA and INB automatically enabled at startup, False-->Vice-versa
address = ReadAddress();
printf("The address = '%X'\n\r", address);
I2C_SlaveAddr( address );
clear();
while(1){
if( dataready == true ){
printf("Command = '%02x' '%02X'\n\r", databyte1, databyte2);
ProcessData( databyte1, databyte2 );
set_timer1(0);
overflow = 0;
counting = true;
dataready = false;
if((counting == true)){
timerone = (get_timer1()/625);
if(timerone>=97){
overflow += 1;
if(( overflow >= 5) ) {
EnableDrivers(False);
printf("Its friday & the rover has stopped !\n\r");
overflow = 0;
counting= false;
delay_ms(10);
Funtion boddies
void EnableDrivers( values ){
if( values ){
output_high( driver_a );
output_high( driver_b );
output_high( driver_c );
output_high( driver_d );
else{
output_low( driver_a );
output_low( driver_b );
output_low( driver_c );
output_low( driver_d );
void SetDCControl( int8 config, unsigned int duty ){
int secs = 3;
int i;
duty >>= 1;
set_pwm1_duty( duty );
printf("Duty %u\n\r", duty);
switch( config )
case 0:
printf("Forward\n\r");
clear();
setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_D | CCP_PULSE_STEERING_C ); // forward correspond to pin RC2 and RC3
output_high(driver_a);
output_low(driver_b);
output_high(driver_c);
output_low(driver_d);
case 1:
for(i=0;i<secs;i++)
printf("Turn left\n\r");
clear();
setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_D | CCP_PULSE_STEERING_C ); // turn left
output_low(driver_c);
output_high(driver_d);
dataready = false;
case 2:
printf("Turn right\n\r");
clear();
setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_D | CCP_PULSE_STEERING_C ); // turn rightt
output_low(driver_a);
output_high(driver_b);
case 3:
printf("Backward\n\r");
clear();
setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_D | CCP_PULSE_STEERING_C ); // backward
default:
printf("Invalid Argument!\n\r");
clear();
setup_ccp1(CCP_PWM | CCP_PWM_H_H );
output_low( PIN_C2);
output_low( PIN_C3);
output_low( PIN_C4);
output_low( PIN_C5);
void clear( void ){
setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_A | CCP_PULSE_STEERING_B | CCP_PULSE_STEERING_C | CCP_PULSE_STEERING_D );
int8 ReadAddress(){
int8 temp = 0xA0;// the base address is 1010000 (i2c address has only 7 bits!!), corresponds to address 0x50
return temp;
void ProcessData( int8 Data1, int8 Data2)
int8 Mode;
int8 Directions;
// determine wich mode is used
Mode = Data1;
Mode >>= 4;
switch( Mode )
case 1:
printf( "mode1\n\r" );
Directions = Data1 & 0x03; // only the two LSB are needed
SetDCControl( Directions, Data2);
default:
printf( "mode unknown\n\r" );
return;
asmboy
Posted: Wed Sep 09, 2009 7:15 am |
look in the F876 .h file
#FUSES "INTRC_IO" // 876 has NO internal oscillator
#FUSES "MCLR" // 876 always has MCLR
#FUSES "IESO" // ditto
#FUSES "FCMEN" /ditto ditto
are NOT valid fuses for the 876
the same for the other problems too
the lack of function/ definition in the.h file ( and , verily - in the PART itself !!) is the root of your problems
very simple on that score
if its not in the header file for fuses && function - its not recognized |
