Problems in code, changing from PIC16F690 to PIC16F876A
amith.srivatsa
PostPosted: Wed Sep 09, 2009 5:47 am     Reply with quote
Dear all,
I just changed from PIC16f690 to PIC16F876A. The PIC is used for motor driver application and it sends PWM to the H-bridge VNH2SP30. The code written for PIC16f690 worked well with no errors.
But now, I am getting some errors, mainly unknown keyword, unknown identifier when I try to compile the same code but this time for PIC16F876A. I just have changed the header files. Can anyone help me in debugging these errors ?
The error messages:
1.
Unknown keyword in #FUSES "INTRC_IO"
Unknown keyword in #FUSES "MCLR"
Unknown keyword in #FUSES "IESO"
Unknown keyword in #FUSES "FCMEN"
2.
Undefined identifier VSS_VDD
Undefined identifier setup_oscillator
Undefined identifier CCP_PWM_H_H
Would appreciate your help a lot, Many thanks in advance...
The code is below:
Sample - To test: Send via i2c to address 0x50 this data--> 0x02107F in order to set the motors to "Forward" & Half speed.
Setup:   pin A5: serial communication
         pin C0,C1: INA and INB for Motor1 (left)
         pin C6,C7: INA and INB for Motor2 (right)
         pin C2,C3: PWM for motor 1 & 2 respectively (speed control)
         pinB4,B6: I2C communication, SDA & SCL
History:
Version 2:
-Automatic Stop after 600 ms function to stop motors when no i2c command has been send
still problems with prescale and div value but is working
Version 1:
- To control speed and direction of two DC motors using two Full H-Bridge VNH2SP30 and a PIC
#include <16F876A.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES MCLR                     //Master Clear pin enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use delay(clock=8000000)
#use rs232(baud=19200, xmit=PIN_A5 ) // used for the serial com
#use i2c(Slave, sda=PIN_B4, scl=PIN_B6 )// used for i2c
Pin defines
#define led PIN_A4
#define driver_a PIN_C0  //INA and INB for motor1
#define driver_b PIN_C1
#define driver_c PIN_C6  //INA and INB for motor2
#define driver_d PIN_C7
#define TYPE 0x01
#define VERSION "V1.4"
#define VERSION_MAJOR 1
#define VERSION_MINOR 4
#define GET_TYPE 0x00
#define GET_VERSION 0x01
#define SET_MOTOR 0x02
Variables
int8 address;
int8 state;
int1 dataready = false;
int1 counting = false;
long int timerone = 0;
int overflow = 0;
int8 mode = 0;
int8 databyte1 = 0;
int8 databyte2 = 0;
Function prototypes
// description: This funtion enables or disables INA,INB imputs for both VNH2SP30 Full-bridges.
// arguments:   Boolean enable
// return:      None
void EnableDrivers( int1 enable );
// description: This funtion sets pwm according to the speed and INA, INB according to command for both motors
// arguments:   int8 config
//              int8 duty
// return:      None
void SetDCControl( int8 config, int8 duty );
// There are some issues with the PWM module, before changing pinout please clear.
void clear( void );
// describtion: this function reads the address
// arguments:   none
// return   :   the full adress ( 8bit wise)
int8 ReadAddress ( void );
// describtion: this function is used to process received data from the I2C bus.
// arguments:   recieved byte 1 and received byte 2
// return   :   none
void ProcessData( int8 byte1, int8 byte2 );
// Interrupt service routine for i2c activty
#int_SSP
void SSP_isr(){
   output_high(led);
   // you will only be interrupted if the address is correct.
   // first check the mode: read or write
   state = i2c_isr_state();
   if(state < 0x80){                     //Master is sending data
      if(state == 0){}
      else if(state == 1)
         mode = i2c_read();
      else if(state == 2)
         databyte1 = i2c_read();
      else if(state == 3)
         databyte2 = i2c_read();
         if( mode == SET_MOTOR)
            dataready = true;
   else if( state == 0x80 ) // master is reading data
      if( mode == GET_TYPE )
         i2c_write( TYPE );
      else if( mode == GET_VERSION)
         i2c_write( VERSION_MAJOR );
   else if( state == 0x81 ) // master is reading data
      i2c_write( VERSION_MINOR );
   output_low(led);
   return;
void main(){
   setup_adc(ADC_OFF);
   //setup_timer_1(T1_DISABLED);
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);//timer1 for automatic stop after 600ms function
   setup_timer_2(T2_DIV_BY_16, 124, 1);  // 1000 Hz, the pwm frequency
   enable_interrupts(INT_SSP);
   setup_oscillator(OSC_8MHZ);
   printf("I2C motor driver with I2C\n\r");//print to serial
   printf("Version %s\n\r", VERSION);
   printf("Made by ROBODOMUS \n\r");
   EnableDrivers( false );//True --> INA and INB automatically enabled at startup, False-->Vice-versa
   address = ReadAddress();
   printf("The address = '%X'\n\r", address);
   I2C_SlaveAddr( address );
   clear();
   while(1){
      if( dataready == true ){
         printf("Command = '%02x' '%02X'\n\r", databyte1, databyte2);
         ProcessData( databyte1, databyte2 );
         set_timer1(0);
         overflow = 0;
         counting = true;
         dataready = false;
      if((counting == true)){
      timerone = (get_timer1()/625);
         if(timerone>=97){
         overflow += 1;
         if(( overflow >= 5) ) {
         EnableDrivers(False);
         printf("Its friday & the rover has stopped !\n\r");
         overflow = 0;
         counting= false;
      delay_ms(10);
Funtion boddies
void EnableDrivers( values ){
   if( values ){
      output_high( driver_a );
      output_high( driver_b );
      output_high( driver_c );
      output_high( driver_d );
   else{
      output_low( driver_a );
      output_low( driver_b );
      output_low( driver_c );
      output_low( driver_d );
void SetDCControl( int8 config, unsigned int duty ){
   int secs = 3;
   int i;
   duty >>= 1;
   set_pwm1_duty( duty );
   printf("Duty %u\n\r", duty);
   switch( config )
      case 0:
         printf("Forward\n\r");
         clear();
         setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_D | CCP_PULSE_STEERING_C );  // forward correspond to pin RC2 and RC3
         output_high(driver_a);
         output_low(driver_b);
         output_high(driver_c);
         output_low(driver_d);
      case 1:
      for(i=0;i<secs;i++)
         printf("Turn left\n\r");
         clear();
         setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_D | CCP_PULSE_STEERING_C ); // turn left
         output_low(driver_c);
         output_high(driver_d);
         dataready = false;
      case 2:
         printf("Turn right\n\r");
         clear();
         setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_D | CCP_PULSE_STEERING_C );  // turn rightt
         output_low(driver_a);
         output_high(driver_b);
      case 3:
         printf("Backward\n\r");
         clear();
         setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_D | CCP_PULSE_STEERING_C ); // backward
      default:
         printf("Invalid Argument!\n\r");
         clear();
         setup_ccp1(CCP_PWM | CCP_PWM_H_H );
         output_low( PIN_C2);
         output_low( PIN_C3);
         output_low( PIN_C4);
         output_low( PIN_C5);
void clear( void ){
   setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_A | CCP_PULSE_STEERING_B | CCP_PULSE_STEERING_C | CCP_PULSE_STEERING_D );
int8 ReadAddress(){
   int8 temp = 0xA0;//  the base address is 1010000 (i2c address has only 7 bits!!), corresponds to address 0x50
   return temp;
void ProcessData( int8 Data1, int8 Data2)
   int8 Mode;
   int8 Directions;
   // determine wich mode is used
   Mode = Data1;
   Mode >>= 4;
   switch( Mode )
      case 1:
         printf( "mode1\n\r" );
         Directions = Data1 & 0x03; // only the two LSB are needed
         SetDCControl( Directions, Data2);
      default:
         printf( "mode unknown\n\r" );
   return;
asmboy
PostPosted: Wed Sep 09, 2009 7:15 am     Reply with quote
look in the F876 .h file
#FUSES "INTRC_IO" // 876 has NO internal oscillator
#FUSES "MCLR" // 876 always has MCLR
#FUSES "IESO" // ditto
#FUSES "FCMEN" /ditto ditto
are NOT valid fuses for the 876
the same for the other problems too
the lack of function/ definition in the.h file ( and , verily - in the PART itself !!) is the root of your problems
very simple on that score
if its not in the header file for fuses && function - its not recognized
