how to printf the remainder ?
johnpoo
PostPosted: Thu Apr 15, 2010 9:31 pm     Reply with quote
How can I printf the result of the modulus operator?
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,PUT
int decimal;
int b;
  decimal = 30;
  b = ((decimal % 2)==0);
  printf( "b = %u\n\r", b );
Thanks.
johnpoo
PostPosted: Thu Apr 15, 2010 9:50 pm     Reply with quote
Actually I want to do a decimal to binary program.
PostPosted: Fri Apr 16, 2010 2:14 am     Reply with quote
b, in your example, is a number just like any other.
However, use the bit tests, a mask, or shift instructions. A lot less work...
For example:
int8 number;
int8 ctr;
int8 mask;
    mask=128;
    number=100;
    for (ctr=0;ctr<8;ctr++) {
       if (mask&number) putc('1');
       else putc('0');
       mask>>=1;
This would output 01100100 (binary representation of 100, output MSb first).
Or:
int8 number;
int8 ctr;
int8 bit;
    number=100;
       bit=shift_left(&number,1,0);
       putc(bit+'0');
Downside of this, is that it destroys 'number' .
