johnpoo
| how to printf the remainder ? |
Posted: Thu Apr 15, 2010 9:31 pm |
How can I printf the result of the modulus operator?
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,PUT
int decimal;
int b;
decimal = 30;
b = ((decimal % 2)==0);
printf( "b = %u\n\r", b );
Thanks. |
johnpoo
Posted: Thu Apr 15, 2010 9:50 pm |
Actually I want to do a decimal to binary program.
Thanks |
Posted: Fri Apr 16, 2010 2:14 am |
b, in your example, is a number just like any other.
However, use the bit tests, a mask, or shift instructions. A lot less work...
For example:
int8 number;
int8 ctr;
int8 mask;
mask=128;
number=100;
for (ctr=0;ctr<8;ctr++) {
if (mask&number) putc('1');
else putc('0');
mask>>=1;
This would output 01100100 (binary representation of 100, output MSb first).
Or:
int8 number;
int8 ctr;
int8 bit;
number=100;
bit=shift_left(&number,1,0);
putc(bit+'0');
Downside of this, is that it destroys 'number' .
