noyz
Delay problem. |
Posted: Fri Aug 14, 2009 9:55 am |
If i use delay_ms(time) with any time the program stops before the delay.
if i don't use delay, my program works just fine.
I've installed 3 version of windows, because I didn't have this kind of problem before, I've tried CCS 4.057, CCS PCWHD v4.084, and the same problem...
Did anyone had this problem before ?
int16 t;
t=100;
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
while ( TRUE )
if(input(PIN_A0))
output_low(PIN_A4);//stop faza scurta/lunga
output_high(PIN_A5);//bec on
output_low(PIN_A2);//proiectoare on
delay_ms(t);
output_low(PIN_A5);//bec off
output_high(PIN_A2);//proiectoare off
else output_high(PIN_A4);
the lst Code: |
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 004
0003: NOP
0004: CALL 3FF
0005: BSF 03.5
0006: MOVWF 10
0007: MOVLW 00
0008: MOVWF 0A
0009: GOTO 01E
.................... #include "C:\Documents and Settings\Noyz2k\My Documents\flashuri noyz\flash12f675.h"
.................... #include <12F675.h>
.................... //////// Standard Header file for the PIC12F675 device ////////////////
.................... #device PIC12F675
.................... #list
.................... #FUSES NOWDT //No Watch Dog Timer
.................... #FUSES INTRC_IO //Low power osc < 200 khz
.................... #FUSES NOCPD //No EE protection
.................... #FUSES NOPROTECT //Code not protected from reading
.................... #FUSES NOMCLR //Master Clear pin used for I/O
.................... #FUSES NOPUT //No Power Up Timer
.................... #FUSES BROWNOUT //Reset when brownout detected
.................... #FUSES BANDGAP_HIGH
.................... #use delay(clock=4 000 000)
000A: MOVLW 29
000B: MOVWF 04
000C: MOVF 00,W
000D: BTFSC 03.2
000E: GOTO 01D
000F: MOVLW 01
0010: MOVWF 21
0011: CLRF 20
0012: DECFSZ 20,F
0013: GOTO 012
0014: DECFSZ 21,F
0015: GOTO 011
0016: MOVLW 4A
0017: MOVWF 20
0018: DECFSZ 20,F
0019: GOTO 018
001A: GOTO 01B
001B: DECFSZ 00,F
001C: GOTO 00F
001D: RETLW 00
001E: CLRF 04
001F: MOVLW 1F
0020: ANDWF 03,F
0021: BCF 1F.6
0022: BSF 03.5
0023: BCF 1F.0
0024: BCF 1F.1
0025: BCF 1F.2
0026: BCF 1F.3
0027: MOVLW 07
0028: BCF 03.5
0029: MOVWF 19
.................... int16 t;
.................... t=100;
002A: CLRF 27
002B: MOVLW 64
002C: MOVWF 26
.................... setup_adc_ports(NO_ANALOGS|VSS_VDD);
002D: BCF 1F.6
002E: BSF 03.5
002F: BCF 1F.0
0030: BCF 1F.1
0031: BCF 1F.2
0032: BCF 1F.3
.................... setup_adc(ADC_OFF);
0033: BCF 03.5
0034: BCF 1F.0
.................... setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
0035: BSF 03.5
0036: MOVF 01,W
0037: ANDLW C7
0038: IORLW 08
0039: MOVWF 01
.................... setup_timer_1(T1_DISABLED);
003A: BCF 03.5
003B: CLRF 10
.................... setup_comparator(NC_NC);
003C: MOVLW 07
003D: MOVWF 19
003E: BSF 03.5
003F: MOVF 05,W
0040: MOVWF 05
0041: MOVLW 03
0042: BCF 03.5
0043: MOVWF 20
0044: DECFSZ 20,F
0045: GOTO 044
0046: MOVF 19,W
0047: BCF 0C.3
.................... setup_vref(FALSE);
0048: BSF 03.5
0049: CLRF 19
.................... while ( TRUE )
.................... if(input(PIN_A0))
004A: BSF 05.0
004B: BCF 03.5
004C: BTFSS 05.0
004D: GOTO 070
.................... output_low(PIN_A4);//stop faza scurta/lunga
004E: BSF 03.5
004F: BCF 05.4
0050: BCF 03.5
0051: BCF 05.4
.................... output_high(PIN_A5);//bec on
0052: BSF 03.5
0053: BCF 05.5
0054: BCF 03.5
0055: BSF 05.5
.................... output_low(PIN_A2);//proiectoare on
0056: BSF 03.5
0057: BCF 05.2
0058: BCF 03.5
0059: BCF 05.2
.................... delay_ms(t);
005A: MOVF 27,W
005B: MOVWF 28
005C: INCF 28,F
005D: DECF 28,F
005E: BTFSC 03.2
005F: GOTO 064
0060: MOVLW FF
0061: MOVWF 29
0062: CALL 00A
0063: GOTO 05D
0064: MOVF 26,W
0065: MOVWF 29
0066: CALL 00A
.................... output_low(PIN_A5);//bec off
0067: BSF 03.5
0068: BCF 05.5
0069: BCF 03.5
006A: BCF 05.5
.................... output_high(PIN_A2);//proiectoare off
006B: BSF 03.5
006C: BCF 05.2
006D: BCF 03.5
006E: BSF 05.2
.................... else output_high(PIN_A4);
006F: GOTO 074
0070: BSF 03.5
0071: BCF 05.4
0072: BCF 03.5
0073: BSF 05.4
0074: BSF 03.5
0075: GOTO 04A
0076: SLEEP
Configuration Fuses:
Word 1: 31D4 NOWDT NOCPD NOPROTECT NOMCLR NOPUT INTRC_IO BROWNOUT BANDGAP_HIGH
Posted: Fri Aug 14, 2009 11:12 am |
What do you mean by "it stops" ?
Does it stop running as a stand-alone program ?
Or does it appear to stop when running it under the debugger ?
Tell us the testing environment. |
noyz
Posted: Fri Aug 14, 2009 7:45 pm |
Proteus 7.1 and the circuit verified with oscilloscope.
In Proteus I've put the PIC, logic input and logic probes.
It stops after doing everything before delay. |
Posted: Sat Aug 15, 2009 9:17 am |
Obvious question. Have you tried removing the delay?.
Add a simple 'delay' count loop of your own making. Does it still stop?.
Things that might apply:
One of the circuits you are switching with your 'output' statements, is spiking the PIC.
How is the watchdog setup?.
There is nothing special about delay. It is just a carefully timed loop. If the code goes wrong _before_ the delay, look what is being done _before_ the delay....
