Delay problem.
noyz
Delay problem.
PostPosted: Fri Aug 14, 2009 9:55 am     Reply with quote
If i use delay_ms(time) with any time the program stops before the delay.
if i don't use delay, my program works just fine.
I've installed 3 version of windows, because I didn't have this kind of problem before, I've tried CCS 4.057, CCS PCWHD v4.084, and the same problem...
Did anyone had this problem before ?
int16 t;
t=100;
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
  while ( TRUE )
   if(input(PIN_A0))
      output_low(PIN_A4);//stop faza scurta/lunga
      output_high(PIN_A5);//bec on
      output_low(PIN_A2);//proiectoare on
      delay_ms(t);
      output_low(PIN_A5);//bec off
      output_high(PIN_A2);//proiectoare off
      else output_high(PIN_A4);
the lst
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   004
0003:  NOP
0004:  CALL   3FF
0005:  BSF    03.5
0006:  MOVWF  10
0007:  MOVLW  00
0008:  MOVWF  0A
0009:  GOTO   01E
.................... #include "C:\Documents and Settings\Noyz2k\My Documents\flashuri noyz\flash12f675.h"
.................... #include <12F675.h>
.................... //////// Standard Header file for the PIC12F675 device ////////////////
.................... #device PIC12F675
.................... #list
.................... #FUSES NOWDT                    //No Watch Dog Timer
.................... #FUSES INTRC_IO                      //Low power osc < 200 khz
.................... #FUSES NOCPD                    //No EE protection
.................... #FUSES NOPROTECT                //Code not protected from reading
.................... #FUSES NOMCLR                   //Master Clear pin used for I/O
.................... #FUSES NOPUT                    //No Power Up Timer
.................... #FUSES BROWNOUT                 //Reset when brownout detected
.................... #FUSES BANDGAP_HIGH
.................... #use delay(clock=4 000 000)
000A:  MOVLW  29
000B:  MOVWF  04
000C:  MOVF   00,W
000D:  BTFSC  03.2
000E:  GOTO   01D
000F:  MOVLW  01
0010:  MOVWF  21
0011:  CLRF   20
0012:  DECFSZ 20,F
0013:  GOTO   012
0014:  DECFSZ 21,F
0015:  GOTO   011
0016:  MOVLW  4A
0017:  MOVWF  20
0018:  DECFSZ 20,F
0019:  GOTO   018
001A:  GOTO   01B
001B:  DECFSZ 00,F
001C:  GOTO   00F
001D:  RETLW  00
.................... void main()
001E:  CLRF   04
001F:  MOVLW  1F
0020:  ANDWF  03,F
0021:  BCF    1F.6
0022:  BSF    03.5
0023:  BCF    1F.0
0024:  BCF    1F.1
0025:  BCF    1F.2
0026:  BCF    1F.3
0027:  MOVLW  07
0028:  BCF    03.5
0029:  MOVWF  19
.................... int16 t;
.................... t=100;
002A:  CLRF   27
002B:  MOVLW  64
002C:  MOVWF  26
....................    setup_adc_ports(NO_ANALOGS|VSS_VDD);
002D:  BCF    1F.6
002E:  BSF    03.5
002F:  BCF    1F.0
0030:  BCF    1F.1
0031:  BCF    1F.2
0032:  BCF    1F.3
....................    setup_adc(ADC_OFF);
0033:  BCF    03.5
0034:  BCF    1F.0
....................    setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
0035:  BSF    03.5
0036:  MOVF   01,W
0037:  ANDLW  C7
0038:  IORLW  08
0039:  MOVWF  01
....................    setup_timer_1(T1_DISABLED);
003A:  BCF    03.5
003B:  CLRF   10
....................    setup_comparator(NC_NC);
003C:  MOVLW  07
003D:  MOVWF  19
003E:  BSF    03.5
003F:  MOVF   05,W
0040:  MOVWF  05
0041:  MOVLW  03
0042:  BCF    03.5
0043:  MOVWF  20
0044:  DECFSZ 20,F
0045:  GOTO   044
0046:  MOVF   19,W
0047:  BCF    0C.3
....................    setup_vref(FALSE);
0048:  BSF    03.5
0049:  CLRF   19
....................   while ( TRUE )
....................    if(input(PIN_A0))
004A:  BSF    05.0
004B:  BCF    03.5
004C:  BTFSS  05.0
004D:  GOTO   070
....................       output_low(PIN_A4);//stop faza scurta/lunga
004E:  BSF    03.5
004F:  BCF    05.4
0050:  BCF    03.5
0051:  BCF    05.4
....................       output_high(PIN_A5);//bec on
0052:  BSF    03.5
0053:  BCF    05.5
0054:  BCF    03.5
0055:  BSF    05.5
....................       output_low(PIN_A2);//proiectoare on
0056:  BSF    03.5
0057:  BCF    05.2
0058:  BCF    03.5
0059:  BCF    05.2
....................       delay_ms(t);
005A:  MOVF   27,W
005B:  MOVWF  28
005C:  INCF   28,F
005D:  DECF   28,F
005E:  BTFSC  03.2
005F:  GOTO   064
0060:  MOVLW  FF
0061:  MOVWF  29
0062:  CALL   00A
0063:  GOTO   05D
0064:  MOVF   26,W
0065:  MOVWF  29
0066:  CALL   00A
....................       output_low(PIN_A5);//bec off
0067:  BSF    03.5
0068:  BCF    05.5
0069:  BCF    03.5
006A:  BCF    05.5
....................       output_high(PIN_A2);//proiectoare off
006B:  BSF    03.5
006C:  BCF    05.2
006D:  BCF    03.5
006E:  BSF    05.2
....................       else output_high(PIN_A4);
006F:  GOTO   074
0070:  BSF    03.5
0071:  BCF    05.4
0072:  BCF    03.5
0073:  BSF    05.4
0074:  BSF    03.5
0075:  GOTO   04A
0076:  SLEEP
Configuration Fuses:
   Word  1: 31D4   NOWDT NOCPD NOPROTECT NOMCLR NOPUT INTRC_IO BROWNOUT BANDGAP_HIGH
PostPosted: Fri Aug 14, 2009 11:12 am     Reply with quote
What do you mean by "it stops" ?
Does it stop running as a stand-alone program ?
Or does it appear to stop when running it under the debugger ?
Tell us the testing environment.
noyz
PostPosted: Fri Aug 14, 2009 7:45 pm     Reply with quote
Proteus 7.1 and the circuit verified with oscilloscope.
In Proteus I've put the PIC, logic input and logic probes.
It stops after doing everything before delay.
PostPosted: Sat Aug 15, 2009 9:17 am     Reply with quote
Obvious question. Have you tried removing the delay?.
Add a simple 'delay' count loop of your own making. Does it still stop?.
Things that might apply:
One of the circuits you are switching with your 'output' statements, is spiking the PIC.
How is the watchdog setup?.
There is nothing special about delay. It is just a carefully timed loop. If the code goes wrong _before_ the delay, look what is being done _before_ the delay....
