NOIOL1WAY fuse and configuration bits
John5788
PostPosted: Mon Aug 10, 2009 12:34 pm     Reply with quote
I am still trying to track a problem down with setting peripheral pins on my PIC24HJ64GP504.
I saw 2 fuses that looked interesting, the IOL1WAY and NOIOL1WAY. I tried setting both of these fuses (exclusively) and noticed that the Peripheral Pin Select Configuration field is always Disabled.
Even if I uncheck the "Configuration bits set in code" box, and try to set the field manually, the field changes back to Disabled upon compilation.
I also tried taking all my code out, just the fuses and a blank main, but that configuration never changes to Enabled.
is this a bug?
bkamen
PostPosted: Mon Aug 10, 2009 3:22 pm     Reply with quote
Unchecking "auto-config" on compile and then fiddling the bits requires immediate program (and debugging if applicable).
The bits will always revert on recompile. That's normal.
As for the #fuse not setting it the way you think - report it to CCS. that may be a bug.
(also check the .LST file to see what it thinks is being set)
-Ben
p.s. BTW, IOL1WAY being DISABLED (NOIOL1WAY) allows multiple settings of the PPS Pin Selects -- maybe not a bad thing for you unless your problem relates to locking them down as IOL1WAY (ENABLED) would do.
John5788
PostPosted: Mon Aug 10, 2009 3:35 pm     Reply with quote
definitely a bug because I did a binary file compare of the two .hex files generated with both of the fuses, and there was no difference except in compilation date.
bkamen
PostPosted: Mon Aug 10, 2009 3:37 pm     Reply with quote
Yep! Let support@ccsinfo.com know about it.
Send them the .LST file as an attachment compiled BOTH ways (and make a short test file if you can for them. It's never fun weeding through 4000 lines of code to show something simple like a #fuse issue)...
Cheers,
-Ben
