John Ilicitean
High-Speed Mode of I2C |
Posted: Thu Jan 12, 2006 6:41 am |
Hello Everyone!!!
I working with PIC16F877 and I want to transmit information across I2c to the conversor ADS1100. In differents programs the ADS1100 not send me the bit acknowledged. I try in fast and slow speed mode,now I want to use the HIGH-SPEED mode(to see if there is for it that not send me the bit acknowledged) but I not as activates this mode.
This is my code:
#include <16F877.h>
#fuses NOWDT,HS, PUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#use i2c(Master,fast,sda=PIN_C4,scl=PIN_C3)
byte r,y,x;
i2c_start();
i2c_write(0x94); //device addres with the low bit=0
i2c_write(0x8c); //Configuration Register
i2c_start();
i2c_write(0x95); //device addres with the low bit=1
r=i2c_read();
y=i2c_read();
x=i2c_read();
i2c_stop();
delay_ms(11);
That I must change to use the HIGH-SPEED mode?? |
Posted: Thu Jan 12, 2006 1:28 pm |
Quote: | now I want to use the HIGH-SPEED mode |
Example:
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW, FAST=1000000) |
John Ilicitean
Posted: Fri Jan 13, 2006 3:59 am |
Hello!!
I proved this option and the compiler have a error because FAST=1000000 don't is option valid.
" Option invalid Bad Option: 1000000"
In declaration of the bus I2C (#use i2c(master,......etc)) it does not allow the option FAST=XXXXX.
That it can do? |
John Ilicitean
Posted: Fri Jan 13, 2006 6:48 am |
Thank's!!!
I'm working to a major frequency.
Now, I must to find because the ADS1100 not send me the bit acknowledged .
Some time ago that I have this problem,I was thinking that I having worked a major frequency It was the solution for the slave send me the bit ACK, but it is not like that.
Also I'm sure that is not hardware problem.
I am doing something badly in my program, but not that!!! ![Sad](images/smiles/icon_sad.gif) |
