High-Speed Mode of I2C
John Ilicitean
PostPosted: Thu Jan 12, 2006 6:41 am     Reply with quote
Hello Everyone!!!
I working with PIC16F877 and I want to transmit information across I2c to the conversor ADS1100. In differents programs the ADS1100 not send me the bit acknowledged. I try in fast and slow speed mode,now I want to use the HIGH-SPEED mode(to see if there is for it that not send me the bit acknowledged) but I not as activates this mode.
This is my code:
#include <16F877.h>
#fuses NOWDT,HS, PUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#use i2c(Master,fast,sda=PIN_C4,scl=PIN_C3)
byte r,y,x;
      i2c_start();
      i2c_write(0x94);      //device addres with  the low bit=0
      i2c_write(0x8c);      //Configuration Register
      i2c_start();
      i2c_write(0x95);      //device addres with  the low bit=1
      r=i2c_read();
      y=i2c_read();
      x=i2c_read();
        i2c_stop();
      delay_ms(11);
That I must change to use the HIGH-SPEED mode??
PostPosted: Thu Jan 12, 2006 1:28 pm     Reply with quote
Example:
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW, FAST=1000000)
John Ilicitean
PostPosted: Fri Jan 13, 2006 3:59 am     Reply with quote
Hello!!
I proved this option and the compiler have a error because FAST=1000000 don't is option valid.
" Option invalid Bad Option: 1000000"
In declaration of the bus I2C (#use i2c(master,......etc)) it does not allow the option FAST=XXXXX.
That it can do?
PostPosted: Fri Jan 13, 2006 4:10 am     Reply with quote
You probably have an old version of the compiler, that doesn't support
that feature. See the following thread which shows how to write to
the i2c baud rate register directly. (This is the SSPADD register.)
http://www.ccsinfo.com/forum/viewtopic.php?t=19257&highlight=sspadd
John Ilicitean
PostPosted: Fri Jan 13, 2006 6:48 am     Reply with quote
Thank's!!!
I'm working to a major frequency.
Now, I must to find because the ADS1100 not send me the bit acknowledged .
Some time ago that I have this problem,I was thinking that I having worked a major frequency It was the solution for the slave send me the bit ACK, but it is not like that.
Also I'm sure that is not hardware problem.
I am doing something badly in my program, but not that!!! Sad Sad Sad
