Function prototype issue?
JohnP
PostPosted: Sun Aug 02, 2009 11:45 am     Reply with quote
I am trying to compile a program made up of snippets of working code from previous projects...
void SerialReceive(void); // apprears earlier in code.
// bunch of configuration
// etc/
// Main Loop
while (1)
//When a packet is received on the tool bus, NewPacket is set.
//Process received packet and reply.
if(NewPacket)
disable_interrupts(INT_RDA); //disable serial port interrupts
NewPacket = FALSE; //clear flag
SerialReceive(); //get received packet
enable_interrupts(INT_RDA); //enable serial port interrupts
if (Tick)
Tick = 0;
output_toggle(PIN_D7); //Show that Timer0 is generating a 1/2 sec timer
fputs( " | HI ! | ",HOST_PC );
output_toggle(PIN_D0); //Toggle the D0 D1 pin pattern
output_toggle(PIN_D1); //
rs232_errors = 0; // clear errors just to clear warning...
}//end of MAIN LOOP
void SerialReceive(void) // compiler does not like this line and
// focuses on the "void" ...
Checksum = 0;
delay_us(50); //short dead time to allow bus master to get ready to receive
if(SerialError) //received an error in packet
CREN = 0; //turn off receiver
putc(Buff[0]); //echo board address
while(!TRMT); //wait for transmit buffer to finish
when I try to compile this I get the DREADED non-specific, utterly confusing; " A numeric expression must appear here..." pointing to the first line of code
This funtion comiles noprmally in other code...and I have looked for obvious missing braces etc. Actually no funtions will compile after my brief main section...So something is hosed in there...but I can't find it.
Any help appreciated...from reading other posts, I see you can get this message from a host of arcane sources...Hoo Boy, what fun!
JPR
bungee-
Re: Funtion prototype issue?
PostPosted: Sun Aug 02, 2009 11:51 am     Reply with quote
JohnP wrote:
I am trying to compile a program mad eup of snippets of working code from previous projects...
JPR
Paste complete code. You probably overlooked something and use CODE for pasting a source it is easier to "debug" Wink
JohnP
Reply
PostPosted: Sun Aug 02, 2009 11:56 am     Reply with quote
Here is the code...implements a ninth bit serial RX funtion...
Works great in other uses...I am clearly missing something simple?
#define RecvTimeout 20000  // increased for debug 6/7/06
// define legal addresses
#define PMTAddress1 70
#define PMTAddress2 80
#define PMTAddress3 90
//  Need to find where these come from?????
#byte  RCSTA2 = 0xF6B    //Receive status control register
#bit  SPEN = 0xF6B.7    //Serial Port Enable
#bit  RX9 = 0xF6B.6     //9-bit receive enable
#bit  CREN = 0xF6B.4    //Receive Enable
#bit  ADDEN = 0xF6B.3   //Address detect enable
#bit  FERR = 0xF6B.2    //framing error
#bit  OERR = 0xF6B.1    //overrun error
#bit  RX9D = 0xF6B.0    //9th bit of received data
#byte TXSTA2 = 0xF6C     //Transmit status and control register
#bit  TX9 = 0xF6C.6     //9-bit transmit enable
#bit  TXEN = 0xF6C.5    //Transmit enable
#bit  TRMT = 0xF6C.1    //Transmit buffer is empty
#bit  TX9D = 0xF6C.0    //9th bit of transmit data
#byte RCREG2 = 0xF6E     //receive register
#byte  PIR1 = 3998
#bit RCIF= 3998.5    //usart receive interrupt flag
int1  NewPacket;
int1  PMT_changed;
int16 Tout;
int8 RecvPacketSize;
int8 PacketSize;
int16 TotPacketSize;
int8 H;
int8 L;
int8 Checksum;
int8 RecvPointer;
int8 Adr;
int8 SerialError;
int8 Status, TempCount;
int1 Tick, toggle;
int16 temperature, temptemp;
unsigned int16 dac_value, pmt_set_value, buf_value, temp_value;
unsigned int16 default_PMT = 44239;  // initialize to 1350 volts
int8 PowerOnTimer;
                     //ready to be xmited
int8  Rcmd;          //received command
int8  Buff[30];      //serial communications buffer
int8  CB;
int8  CL;
int8  CH;
int8  ReceivedAddress;     //value read from serial port with 9th bit set
int   *pntr;
int16 CVsetpoint;
int16 Timer0_Clk;
//int8  B1, B2, B3, B4, B5, B6, B7, B8;    // temporary variables
void ReadTemp(void);
void SendStatus(void);
void SetSerialNumber(void);
void SendReport(void);
void ChangePMT(void);
void IncrementPMT(void);
void DecrementPMT(void);
void WriteCalDate(void);
void WritePMTVoltage(void);
void Write_new_SN(void);
void WriteMfgDate(void);
void WriteFirmwareVersion(void);
void WriteHardwareVersion(void);
void SetMfgDate(void);
void SetFirmwareRev(void);
void SetHardwareRev(void);
void SendPMTVoltage(void);
*  RTCC - Timer 0 Interrupt                                         *
#int_TIMER0
TIMER0_ISR()
set_timer0(15536);     // reload for 10 msec tick, based on value from above number
                       // = 655356 - (.01/(8 /40,000,000))
//  this gives a 94.67 hz pulse so a lot closer than the previous value
Timer0_Clk++;           // 10 msec clock event counter
if (Timer0_Clk > 50)
   Tick = 1;      //500 msec clock tick
}// end of Timer0 ISR
#int_RDA
void  RDA_isr(void)
// handler for input commands from the Host PC would go here...
// STB Serial ISR
//  Receive Interrupt - when address bit is set
//    in 1st xmission matches the BoardAddress
#int_RDA2
void  RDA2_isr(void)
int CS;
NewPacket = 0;
SerialError = 0;
ReceivedAddress = RCREG2;      //get byte from receive buffer
if ( (ReceivedAddress == PMTAddress1) || (ReceivedAddress == PMTAddress2) || (ReceivedAddress == PMTAddress3) )
   //output_high(PIN_B6);     // for debug!!!! Set while wating for next byte
   NewPacket = 1;       //set flag for new packet is coming
   ADDEN = 0;           //allow receiver to get the rest of the packet
   //output_low(PIN_B6);
   Buff[0] = ReceivedAddress;  //shove address into 1st slot...
//Receive packet size High Byte
   Tout = RecvTimeout;
   while(RCIF == 0)        //wait for next byte in receiver
     Tout--;
     //output_high(PIN_B6);     // for debug!!!!Set while wating for next byte
     if(Tout == 0)
         SerialError = 130;           //Timeout error
         goto ErrorTest;
   //output_low(PIN_B6);              // for debug!!!! 2nd byte arrived
   Buff[1] = RCREG2;                  //get size byte from serial port
// Receive packet size Low byte
   Tout = RecvTimeout;
     Tout--;
     if(Tout == 0)
         goto ErrorTest;
   //output_low(PIN_B6);     // for debug!!!!last size byte arrived
   Buff[2] = RCREG2;                    //get byte from serial port
   RecvPacketSize = Buff[2];       //add size and checksum to packet size
// --- receive packet
   RecvPointer = 3;       //position pointer at first byte
// receive rest of packet past the packet size bytes.....
   while(RecvPointer < (RecvPacketSize+1))
     Tout = RecvTimeout;
     while(RCIF == 0)
       Tout--;
    //   output_high(PIN_B6);     // for debug!!!!Set while wating for next byte
       if(Tout == 0)
          SerialError = 130;            //Timeout error = 0x82
          goto ErrorTest;
   //  output_low(PIN_B6);            // for debug!!!! next byte here
     Buff[RecvPointer] = RCREG2;     //save packet data in buffer array
     RecvPointer++;
     }// end of while RCVpointer <= RecvPacetsize
     CS = 0;
     RecvPointer = 1;
     while(RecvPointer < Buff[2])
      CS = CS + Buff[RecvPointer];
      RecvPointer++;
   CS = ~(CS) + 1;       //CheckSum is now 2's complement
   if (CS != Buff[RecvPacketSize])
      SerialError = 129;                  //checksum error = 0x81
   }// End of IF Rc'd addr = Board Address
ErrorTest:
ADDEN = 1;                    //enable interrupt when address bit is set
}// end of RDA2 ISR
   setup_adc_ports(AN0|VSS_VDD);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_20);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_spi2(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_2);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED, 0,1);
   setup_timer_3(T3_DISABLED);
   setup_timer_4(T4_DISABLED, 0,1);
   setup_vref(FALSE);
   TX9D = 0;                        //9th bit of transmitted data is always low
   TX9 = 1;                         //Enable 9-bit transmits
   RX9 = 1;                         //Enable 9-bit receives
   setup_low_volt_detect(FALSE);
   set_tris_a(0xFF);    // all inputs
   set_tris_b(0xFF);    // all inputs
   set_tris_c(0x80);    //Set up for UART1 = HOST_PC on C7(Rx)Input and C6 (TX) and all others are outputs
   set_tris_d(0);       //All outputs to drive diodes and diagnostics
   set_tris_e(0xFF);    // all inputs
   set_tris_f(0xFF);    // all inputs
   set_tris_g(0xFF);    // all inputs
   set_tris_h(0x80);    //Set up for UART2 = STB on H7 (Rx)Input and H6 (TX) and all others are outputs
   set_tris_j(0xFF);    // all inputs
//   setup_uart(115200, HOST_PC);
//   setup_uart(115200, STB);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// Crive pin D0 high to turn on diode D1
   output_high(PIN_D0);       //Turn on D1 to signify we made it this far!!!
   output_high(PIN_D1);
   output_high(PIN_D2);
   output_high(PIN_D3);
   output_high(PIN_D4);
   output_high(PIN_D5);
   output_high(PIN_D6);
   output_high(PIN_D7);
   output_low(PIN_D1);
   output_low(PIN_D2);
   output_low(PIN_D3);
   output_low(PIN_D4);
   output_low(PIN_D5);
   output_low(PIN_D6);
   output_low(PIN_D7);
   Timer0_Clk = 0;
   enable_interrupts(INT_RDA);;
   enable_interrupts(INT_RDA2);
   Checksum = 0;
//  Main Loop
   while (1)
   if(NewPacket)
  if (Tick)
      Tick = 0;
   }//end of MAIN LOOP
   Checksum = 0;
      putc(0);                   // high byte of num. of bytes
      putc(4);                   //1 byte command
      putc(SerialError);         //error code
      Checksum = ~(4 + SerialError) + 1;  // CS now 2's complement
      putc(Checksum);                    //checksum
      goto SerialEnd;
        switch (Buff[3])           //sort the received command...USES 4th BYTE FOR CHLS FORMAT
           case 's':
               //SendStatus();
           case 'm':
               //SetMfgDate();  // write mfg date to eeprom
           case 'n':
               //SetSerialNumber();
           case 'f':
               //SetFirmwareRev(); // write firmware date to eeprom
           case 'H':
               //SetHardwareRev(); //write hardware version to eeprom
           case 50:
               Buff[2] = 50;              //error command
           case 'r':
               //SendReport();
           case 'i':
               //IncrementPMT();
           case 'l':
               //DecrementPMT();
           case 'c':
               //WriteCalDate();
           case 'P':
               WritePMTVoltage();
           case 'V':
               //SendPMTVoltage();
           default:
               Buff[1] = 0;  //(1 byte reply) received command is
                              //not supported
               Buff[2] = 4;   // low byte of # bytes in block
               Buff[3] = 131;  //bad command received
// Command selection/action done
// Send response
      Checksum = 0;
      for(RecvPointer = 1; RecvPointer < PacketSize; RecvPointer++)
         Checksum = Checksum + Buff[RecvPointer];
      Buff[Buff[2]] = ~(Checksum) + 1;
      for(RecvPointer = 0; RecvPointer <= PacketSize; RecvPointer++)
         putc(Buff[RecvPointer]);
SerialEnd:
      CREN = 1;                  //turn on receiver
      setup_wdt(WDT_ON);
      restart_wdt();
   } //end of SerialReceive
}// Program end
JohnP
Prototype problem wa BRAIN problem
PostPosted: Sun Aug 02, 2009 12:16 pm     Reply with quote
Found it...
I had the added functions stuck in before the final ending curly brace of main...stupid error...wonderfully non-specific compiler error...
Sorry to bother the Illuminati with this triffle...
JPR
