jk726 Guest
PIC to PIC communication using i2c |
Posted: Fri Jul 31, 2009 12:49 am |
Hi.
Using 2 microcontrollers, I want to make a system in which
first PIC gives instructions via i2c interface to the second PIC
and based on the instruction given, the second PIC displays data via LCD.
Thus,
1st PIC ---(1byte(for RS)+1byte(for character or instruction))-->2nd PIC---->LCD display
After getting into more complex coding, I wanted to see if I can send 2 bytes via I2c.
After reading some posts and help file, I tested following code.
First, I tried to see if I could send one byte using following code.
Master:
#include<16F886.h>
#include<def_16f886.h>
#fuses intrc_io, noprotect
#use delay(clock = 4000000)
#use i2c(master, sda = pin_c4, scl = pin_c3)
void main(void){
osccon = 0x41;
while(1){
i2c_start();
i2c_write(0xa0);
i2c_write('A');
i2c_stop();
Slave:
#include<16f886.h>
#include<flex_lcd.h>
#fuses intrc_io, noprotect, debug
#use i2c(slave, sda = pin_c4, scl = pin_c3, address = 0xa0)
int8 address = 0;
int8 buffer[5] = {0, 0, 0, 0, 0};
int8 incoming = 0;
int8 first_byte = 0;
int8 second_byte = 0;
int8 state = 0;
#int_ssp
void ssp_interupt ()
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
incoming = i2c_read(0);
if(state == 0x80) //Master is requesting data
i2c_write(buffer[address]);
LCD_gotoxy(1,1);
delay_ms(1);
lcd_putc(incoming);
void main(void){
enable_interrupts(int_ssp);
enable_interrupts(global);
osccon = 0x41;
lcd_send_byte(0,ALL_CLEAR);
while(1){
Turns out, send first byte works well.
Then, I tried to send two bytes (which didn't work).
First byte I want to send is 'A' and the second byte is 'B' for simulation.
Master:
#include<16F886.h>
void main(void){
osccon = 0x41;
while(1){
i2c_start();
i2c_write(0xa0);
i2c_write('A');
//i2c_start(); I experimented with this command.
i2c_write('B');
i2c_stop();
Slave:
#include<16f886.h>
int8 address = 0;
int8 incoming = 0;
int8 state = 0;
#int_ssp
//First received byte is address
if(state==0) first_byte = incoming;
if(state==1) second_byte = incoming;
LCD_gotoxy(1,1);
delay_ms(1);
lcd_putc(first_byte);
lcd_putc(second_byte);
void main(void){
osccon = 0x41;
while(1){
Frankly, I have no idea what
Code: | state = i2c_isr_state(); |
statement really means (the help file only specifies that for some range, it means the master said read, or the master said write).
Did I do something wrong? or did I miss anything? |
Re: PIC to PIC communication using i2c |
Posted: Fri Jul 31, 2009 7:28 am |
jk726 wrote: | Frankly, I have no idea what
statement really means (the help file only specifies that for some range, it means the master said read, or the master said write). | The manual is not too bad in this respect, but one piece of information is missing: the returned state value is a 'counter'. For every byte received in this message it will count up until it resets when the next message starts.
Code: | if(state==0) first_byte = incoming;
if(state==1) second_byte = incoming; | If you look in the example program ex_slave.c you will see the first byte starts at state==1, not at 0.
Note that this implies a maximum message length of 0x7F bytes (excluding the address). I don't know the I2C specifications well enough to say if this limitation comes from the standard or from CCS. |
