PIC to PIC communication using i2c
jk726
PostPosted: Fri Jul 31, 2009 12:49 am     Reply with quote
Hi.
Using 2 microcontrollers, I want to make a system in which
first PIC gives instructions via i2c interface to the second PIC
and based on the instruction given, the second PIC displays data via LCD.
Thus,
1st PIC ---(1byte(for RS)+1byte(for character or instruction))-->2nd PIC---->LCD display
After getting into more complex coding, I wanted to see if I can send 2 bytes via I2c.
After reading some posts and help file, I tested following code.
First, I tried to see if I could send one byte using following code.
Master:
#include<16F886.h>
#include<def_16f886.h>
#fuses intrc_io, noprotect
#use delay(clock = 4000000)
#use i2c(master, sda = pin_c4, scl = pin_c3)
void main(void){
   osccon = 0x41;
   while(1){
      i2c_start();
      i2c_write(0xa0);
      i2c_write('A');
      i2c_stop();
Slave:
#include<16f886.h>
#include<flex_lcd.h>
#fuses intrc_io, noprotect, debug
#use i2c(slave, sda = pin_c4, scl = pin_c3, address = 0xa0)
int8 address = 0;
int8 buffer[5] = {0, 0, 0, 0, 0};
int8 incoming = 0;
int8 first_byte = 0;
int8 second_byte = 0;
int8 state = 0;
#int_ssp
void ssp_interupt ()
   state = i2c_isr_state();
   if(state < 0x80)                     //Master is sending data
      incoming = i2c_read(0);
   if(state == 0x80)                     //Master is requesting data
      i2c_write(buffer[address]);
   LCD_gotoxy(1,1);
   delay_ms(1);
   lcd_putc(incoming);
void main(void){
   enable_interrupts(int_ssp);
   enable_interrupts(global);
   osccon = 0x41;
   lcd_init();
   lcd_send_byte(0,ALL_CLEAR);
   while(1){
Turns out, send first byte works well.
Then, I tried to send two bytes (which didn't work).
First byte I want to send is 'A' and the second byte is 'B' for simulation.
Master:
#include<16F886.h>
void main(void){
   osccon = 0x41;
   while(1){
      i2c_start();
      i2c_write(0xa0);
      i2c_write('A');
      //i2c_start();          I experimented with this command.
      i2c_write('B');
      i2c_stop();
Slave:
#include<16f886.h>
int8 address = 0;
int8 incoming = 0;
int8 state = 0;
#int_ssp
                //First received byte is address
      if(state==0) first_byte = incoming;
      if(state==1) second_byte = incoming;
   LCD_gotoxy(1,1);
   delay_ms(1);
   lcd_putc(first_byte);
   lcd_putc(second_byte);
void main(void){
   osccon = 0x41;
   lcd_init();
   while(1){
Frankly, I have no idea what
statement really means (the help file only specifies that for some range, it means the master said read, or the master said write).
Did I do something wrong? or did I miss anything?
Re: PIC to PIC communication using i2c
PostPosted: Fri Jul 31, 2009 7:28 am     Reply with quote
The manual is not too bad in this respect, but one piece of information is missing: the returned state value is a 'counter'. For every byte received in this message it will count up until it resets when the next message starts.
If you look in the example program ex_slave.c you will see the first byte starts at state==1, not at 0.
Note that this implies a maximum message length of 0x7F bytes (excluding the address). I don't know the I2C specifications well enough to say if this limitation comes from the standard or from CCS.
