ymoona
Joined: 20 Mar 2005 Posts: 32 Location: Heiloo, the Netherlands
| ENC28J60 + 18f452 reset issue |
Posted: Sun Jul 26, 2009 10:28 am |
I'm trying to get TCP/IP working on my PIC-WEB.
this is how my ccstcpip.h looks
// ccstcpip.h - Common code shared among all Embedded Internet/Embedded
// Ethernet tutorial book examples.
// If you are using a CCS Embedded Ethernet Board (labeled PICENS, which
// has an MCP ENC28J60) then define STACK_USE_CCS_PICENS to TRUE.
// If you are using a CCS Embedded Internet Board (labeled PICNET, which
// has a Realtek RTL8019AS and a 56K Modem) then define STACK_USE_CCS_PICNET
// to TRUE.
// 10/25/06
// - Added STACK_USE_CCS_PICEEC
// - ExampleUDPPacket[] UDP header length fixed
// 2008.12.20 - JGSCHMIDT
// - added STACK_USE_CCS_OLXMINI for Olimex Mini-Web board
#define STACK_USE_CCS_PICENS 0 //18f4620 + enc28j60
#define STACK_USE_CCS_PICNET 0 //18f6722 + realtek
#define STACK_USE_CCS_PICEEC 0 //18f97j60
#define STACK_USE_CCS_OLXMINI 0 //Olimex Mini-Web 18f25j10 + enc28j60
#define STACK_USE_CCS_OLXWEB 1 //Olimex Pic-Web 18f452 + enc28j60
#if STACK_USE_CCS_PICENS
#define STACK_USE_MCPENC 1
#if STACK_USE_CCS_OLXMINI
#if STACK_USE_CCS_OLXWEB
#if STACK_USE_CCS_PICEEC
#define STACK_USE_MCPINC 1
#include <18F4620.h>
#use delay(clock=40M)
#fuses H4, NOWDT, NOLVP, NODEBUG
#elif STACK_USE_CCS_PICNET
#include <18F6722.h>
#elif STACK_USE_CCS_PICEEC
#include <18F67J60.h>
//#use delay(clock=41666667)
//#fuses NOWDT, NODEBUG, H4_SW, NOIESO, NOFCMEN, PRIMARY
#use delay(clock=25M)
#fuses NOWDT, NODEBUG, HS, NOIESO, NOFCMEN, PRIMARY, ETHLED
#elif STACK_USE_CCS_PICNET_OLD
#include <18F6720.h>
#use delay(clock=20M)
#fuses HS, NOWDT, NOLVP, NODEBUG
#define STACK_USE_CCS_PICNET TRUE
#elif STACK_USE_CCS_OLXMINI
#include <18F25J10.h>
#use delay(clock=40M, oscillator=10M)
#fuses H4_SW, NOWDT, NODEBUG
#elif STACK_USE_CCS_OLXWEB
#include <18F452.h>
#use delay(clock=40000000)
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOSTVREN //Stack full/underflow will cause reset
#FUSES NOLVP //No Low Voltage Programming on B3(PIC16) or B5(PIC18)
#else
#error You need to define your custom hardware
// There is no level-shifter (MAX3232) on the board so I could not
// use the UART
#use rs232(baud=9600, XMIT=PIN_A1, INVERT)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stop=1)
#else
#include "tcpip/stacktsk.c" //include Microchip TCP/IP Stack
#include "tcpip/mlcd.c"
#define BUTTON1_PRESSED() (!input(PIN_A4))
#define USER_LED1 PIN_A5
#define USER_LED2 PIN_B4
#define USER_LED3 PIN_B5
#define LED_ON output_low
#define LED_OFF output_high
#define STANDARD_ADC_STRING "AN0"
#define STANDARD_ADC_CHANNEL 0
void init_user_io(void) {
setup_adc_ports(AN0);
*0xF92=(*0xF92 & 0xDF) | 0x11; //a5 output, a4 and a0 input
*0xF93=*0xF93 & 0xCF; //b4 and b5 output
LED_OFF(USER_LED1);
LED_OFF(USER_LED2);
LED_OFF(USER_LED3);
set_adc_channel(0);
#include "tcpip/elcd.c"
#define USER_LED1 PIN_B3
#define STANDARD_ADC_STRING "AN2"
#define STANDARD_ADC_CHANNEL 2
setup_adc_ports(AN0_TO_AN2);
set_adc_channel(2);
*0xF92=*0xF92 & 0xFC; //a0 and a1 output
*0xF93=*0xF93 & 0xC7; //b3, b4 and b5 output
LED_OFF(USER_LED1);
LED_OFF(USER_LED2);
LED_OFF(USER_LED3);
set_adc_channel(2);
#elif STACK_USE_CCS_OLXMINI // JGS 2008.12.20
// #include "tcpip/elcd.c"
#define BUTTON1_PRESSED() (!input(PIN_B0))
#define USER_LED1 PIN_C2
// #define STANDARD_ADC_STRING "AN2"
// #define STANDARD_ADC_CHANNEL 2
// setup_adc(ADC_CLOCK_INTERNAL);
// setup_adc_ports(AN0_TO_AN2);
// set_adc_channel(2);
// *0xF92=*0xF92 & 0xFC; //a0 and a1 output
// *0xF93=*0xF93 & 0xC7; //b3, b4 and b5 output
LED_OFF(USER_LED1);
// LED_OFF(USER_LED2);
// LED_OFF(USER_LED3);
#define USER_LED1 PIN_D5
LED_OFF(USER_LED1);
#else
#include "tcpip/dlcd.c"
#define BUTTON2_PRESSED() (!input(PIN_B1))
#define USER_LED1 PIN_B2
setup_adc(ADC_CLOCK_INTERNAL );
setup_adc_ports(ANALOG_AN0_TO_AN1);
*0xF92=*0xF92 | 3; //a0 and a1 input (for ADC)
*0xF93=(*0xF93 & 0xEB) | 3; //B0 and B1 input, B2 and B4 output
LED_OFF(USER_LED1);
LED_OFF(USER_LED2);
set_adc_channel(0);
void MACAddrInit(void) {
MY_MAC_BYTE1=0;
MY_MAC_BYTE2=2;
MY_MAC_BYTE3=3;
MY_MAC_BYTE4=4;
MY_MAC_BYTE5=5;
MY_MAC_BYTE6=6;
void IPAddrInit(void) {
//IP address of this unit
MY_IP_BYTE1=192;
MY_IP_BYTE2=168;
MY_IP_BYTE3=100;
MY_IP_BYTE4=7;
//network gateway
MY_GATE_BYTE1=192;
MY_GATE_BYTE2=168;
MY_GATE_BYTE3=100;
MY_GATE_BYTE4=1;
//subnet mask
MY_MASK_BYTE1=255;
MY_MASK_BYTE2=255;
MY_MASK_BYTE3=255;
MY_MASK_BYTE4=0;
char ExampleIPDatagram[] = {
0x45, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00,
0x64, 0x11, 0x2A, 0x9D, 0x0A, 0x0B, 0x0C, 0x0D,
0x0A, 0x0B, 0x0C, 0x0E
char ExampleUDPPacket[] = {
0x04, 0x00, 0x04, 0x01, 0x00, 0x08, 0x00, 0x00,
0x01, 0x02, 0x03, 0x04
My HARDWARE.H looks like this.
//// HARDWARE.H ////
//// Hardware I/O definitions and TCP/IP stack configuration settings. ////
//// These values will probably change with each application. ////
//// RELEASE HISTORY: ////
//// Jan 15, 2004: MODEM_RESPONSE_TIMEOUT and MODEM_CONNECT_TIMEOUT ////
//// moved to here. ////
//// Jan 09, 2004: Initial Public Release ////
//// (C) Copyright 1996,2004 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
#IFNDEF ___TCPIP_STACK_CONFIGURATION
#define ___TCPIP_STACK_CONFIGURATION
#ifndef STACK_USE_CCS_PICNET
#define STACK_USE_CCS_PICNET FALSE
#ifndef STACK_USE_CCS_PICENS
#define STACK_USE_CCS_PICENS FALSE
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#if STACK_USE_CCS_PICNET || STACK_USE_CCS_PICEEC || STACK_USE_CCS_EWL3V
#use fast_io(F)
//// VARIOUS MODEM SETTINGS.
#DEFINE MODEM_DCD PIN_G3
#DEFINE MODEM_RESET PIN_G4
#define MODEM_TX PIN_G1
#define MODEM_RX PIN_G2
#DEFINE MODEM_INIT_STR "ATM1L3&K0" //speaker on, volume high, no hw flow control
#DEFINE MODEM_DIAL_STR "ATDT"
#DEFINE MODEM_BAUD_RATE 115200
#DEFINE MODEM_RESPONSE_TIMEOUT 2000 //time to wait for a response to an AT command (in ms)
#DEFINE MODEM_CONNECT_TIMEOUT 120000 //time to wait for modem to make a connection (in ms)
//// VARIOUS MAC/NIC SETTINGS.
//Latch and Directional control SFR locations for the 3 control pins
#define NIC_RESET_LAT LATE_RE7
#define NIC_IOW_LAT LATE_RE6
#define NIC_IOR_LAT LATE_RE5
#define NIC_RESET_TRIS TRISE_RE7
#define NIC_IOW_TRIS TRISE_RE6
#define NIC_IOR_TRIS TRISE_RE5
//Latch and Directional control SFR locations for the 5bit address port
#define NIC_ADDR_LAT LATE
#define NIC_ADDR_TRIS TRISE
//Latch, Directional and I/O SFR locations for the 8bit data port
#define NIC_DATA_IO PORTF
#define NIC_DATA_LAT LATF
#define NIC_DATA_TRIS TRISF
//This macro takes an address and properly outputs it on the latch register, and sets proper pins to output.
//Leaves other pins alone.
#define WRITE_NIC_ADDR(a) NIC_ADDR_LAT = (NIC_ADDR_LAT & 0xE0)|a; \
NIC_ADDR_TRIS = NIC_ADDR_TRIS & 0xE0
#elif STACK_USE_CCS_PICENS
#define PIN_ENC_MAC_SO PIN_C4 // PIC <<<< ENC
#define PIN_ENC_MAC_SI PIN_C5 // PIC >>>> ENC
#define PIN_ENC_MAC_CLK PIN_C3
#define PIN_ENC_MAC_CS PIN_D1
#define PIN_ENC_MAC_RST PIN_D0
#define PIN_ENC_MAC_INT PIN_B0
#define PIN_ENC_MAC_WOL PIN_B1
#define ENC_MAC_USE_SPI TRUE //due to an errata in the ENC28J60, you should always use HW SPI to assure that SPI clock is over 8MHz!
#define mac_enc_spi_tris_init() TRISB=(TRISB | 0b11); TRISC = (TRISC & 0b11010111) | 0x10; TRISD=TRISD & 0xF4 //was 0xFC
#define PIN_ENC_MAC_CS PIN_B3
#define PIN_ENC_MAC_RST PIN_B5
#define PIN_ENC_MAC_INT PIN_B2
#define mac_enc_spi_tris_init() TRISB=(0b110); TRISC = (TRISC & 0b11010111) | 0x10; TRISD=TRISD & 0xF4//was 0xFC
#define PIN_ENC_MAC_CS PIN_B4
#elif STACK_USE_CCS_EWL5V
#define PIN_ENC_MAC_CS PIN_A4
#define PIN_ENC_MAC_WOL PIN_B3
#define mac_enc_spi_tris_init() TRISB=(TRISB | 0b00001100)&0b11011111; TRISC = (TRISC & 0b11010111) | 0x10; TRISA=TRISA & 0b11101111
#elif STACK_USE_CCS_PICEEC||STACK_USE_CCS_EWL3V
//no hardware definitions - everything is internal
#else
#error Please define your MAC/NIC I/O settings
//// SET TCP_NO_WAIT_FOR_ACK TO FALSE IF TCP STACK SHOULD WAIT FOR ACK FROM
//// REMOTE HOST BEFORE TRANSMITTING ANOTHER PACKET. THIS MAY REDUCE THROUGHPUT.
//// DEFAULT VALUE (TRUE) GETS LOADED IN TCP.H IF THIS LINE IS REMOVED.
#define TCP_NO_WAIT_FOR_ACK FALSE
///DEFAULT HARDCODED IP ADDRESSES.
/// FUTURE APPLICATIONS MAY WANT TO SAVE THESE TO AN EEPROM.
/// OR USE AUTO IP ASSIGNMENT (DHCP).
/// NO TWO DEVICES ON A NETwORK CAN HAVE THE SAME IP ADDRESS
#define MY_DEFAULT_IP_ADDR_BYTE1 10 //IP ADDRESS
#define MY_DEFAULT_IP_ADDR_BYTE2 10 // This unit's IP address.
#define MY_DEFAULT_IP_ADDR_BYTE3 5
#define MY_DEFAULT_IP_ADDR_BYTE4 15
#define MY_DEFAULT_MASK_BYTE1 0xff //NETMASK
#define MY_DEFAULT_MASK_BYTE2 0xff // Netmask tells the IP / ARP stack which
#define MY_DEFAULT_MASK_BYTE3 0xff // IP's are on your local network.
#define MY_DEFAULT_MASK_BYTE4 0x00
#define MY_DEFAULT_GATE_BYTE1 192 //GATEWAY IP ADDRESS
#define MY_DEFAULT_GATE_BYTE2 168 // Gateway acts as a conduit between two networks.
#define MY_DEFAULT_GATE_BYTE3 100
#define MY_DEFAULT_GATE_BYTE4 1
///DEFAULT HARDCODED MAC ADDRESS.
/// FUTURE APPLICATIONS MAY WANT TO SAVE THIS TO AN EEPROM, OR GENERATE
/// A DYNAMIC ONE BASED UPON UNIT'S SERIAL NUMBER.
/// NO TWO DEVICES ON THE SAME ETHERNET NETWORK CAN HAVE THE SAME MAC ADDRESS.
#define MY_DEFAULT_MAC_BYTE1 0x00
#define MY_DEFAULT_MAC_BYTE2 0x04
#define MY_DEFAULT_MAC_BYTE3 0xa3
#define MY_DEFAULT_MAC_BYTE4 0x00
#define MY_DEFAULT_MAC_BYTE5 0x00
#define MY_DEFAULT_MAC_BYTE6 0x00
///Maximum sockets to be defined.
/// Note that each socket consumes 36 bytes of RAM.
/// If you remove this, a default value will be loaded in stacktsk.h
#ifndef MAX_SOCKETS
#define MAX_SOCKETS 5
///Avaialble UDP Socket
/// DCHP takes 1 socket.
#ifndef MAX_UDP_SOCKETS
#define MAX_UDP_SOCKETS 2
///BUFFER SIZE DEFINITIONS
/// For SLIP, there can only be one transmit and one receive buffer.
/// Both buffer must fit in one bank. If bigger buffer is required,
/// you must manually locate tx and rx buffer in different bank
/// or modify your linker script file to support arrays bigger than
/// 256 bytes.
/// I think Microchip needs MAC_RX_BUFFER_SIZE to equal MAC_TX_BUFFER_SIZE
/// For PPP, there can only be one transmit and one receive buffer.
/// You can receive messages larger than the receive buffer if your
/// routines are fast enough. You cannot transmit messages larger
/// than the TX buffer. The larger the buffer you can make, the better.
/// BUG: MAC_RX_BUFFER_SIZE must equal MAC_TX_BUFFER_SIZE
/// For Ethernet, the Ethernet controler has many buffers that are
/// 1k in size. Only one buffer is used for TX, rest are for RX.
/// Unlike SLIP and PPP, no RAM is used for these buffers.
#if STACK_USE_MAC
#define MAC_TX_BUFFER_SIZE 1024 //do not modify this line
#define MAC_TX_BUFFER_COUNT 1 //do not modify this line
#elif STACK_USE_PPP
#elif STACK_USE_SLIP
#define MAC_TX_BUFFER_SIZE 250
#define MAC_RX_BUFFER_SIZE MAC_TX_BUFFER_SIZE //do not modify this line unless you are certain you know what you're doing
The test code looks like this:
#define STACK_USE_ICMP 1
#define STACK_USE_ARP 1
#define STACK_USE_DHCP 1
//#define MPFS_USE_PGRM 1
#include "ccstcpip.h"
#define LED pin_d5
#define DISPLAYWAIT 1 // seconds
void LCDTask(void) {
// no LCD on mini-web so continue with serial output
static TICKTYPE lastTick;
static enum {LCD_Display=0, LCD_Wait=1} state=0;
switch(state) {
case LCD_Display:
if (!MACIsLinked()) {
printf("No Ethernet\n");
else if (!DHCPIsBound()) {
printf("DCHP Not Bound\n");
else {
printf("%u.%u.%u.%u\n", MY_IP_BYTE1, MY_IP_BYTE2,
MY_IP_BYTE3, MY_IP_BYTE4);
lastTick=TickGet();
state=LCD_Wait;
case LCD_Wait:
if (TickGetDiff(TickGet(), lastTick) >= TICKS_PER_SECOND * DISPLAYWAIT)
state=LCD_Display;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_oscillator(FALSE);
while( 1 )
delay_ms(100); // allow some settle time
printf("CCS TCP/IP TUTORIAL, EXAMPLE 11 (DHCP)\r\n");
MACAddrInit();
printf("MACAddrInit, done\r\n");
StackInit();
printf("StackInit, done\r\n");
while(TRUE) {
StackTask();
LCDTask();
The problem is: afer StackTask has been called a few times the PIC will reset. Am I forgetting something? I used http://www.ccsinfo.com/forum/viewtopic.php?t=37139 as an example for my code.
Compiler version 4.088 _________________ checkout my site: www.ymoona.com/wiki |
