ENC28J60 + 18f452 reset issue
ymoona
PostPosted: Sun Jul 26, 2009 10:28 am     Reply with quote
I'm trying to get TCP/IP working on my PIC-WEB.
this is how my ccstcpip.h looks
// ccstcpip.h - Common code shared among all Embedded Internet/Embedded
// Ethernet tutorial book examples.
// If you are using a CCS Embedded Ethernet Board (labeled PICENS, which
// has an MCP ENC28J60) then define STACK_USE_CCS_PICENS to TRUE.
// If you are using a CCS Embedded Internet Board (labeled PICNET, which
// has a Realtek RTL8019AS and a 56K Modem) then define STACK_USE_CCS_PICNET
// to TRUE.
// 10/25/06
//  - Added STACK_USE_CCS_PICEEC
//  - ExampleUDPPacket[] UDP header length fixed
// 2008.12.20 - JGSCHMIDT
// - added STACK_USE_CCS_OLXMINI for Olimex Mini-Web board
#define STACK_USE_CCS_PICENS     0 //18f4620 + enc28j60
#define STACK_USE_CCS_PICNET     0 //18f6722 + realtek
#define STACK_USE_CCS_PICEEC     0 //18f97j60
#define STACK_USE_CCS_OLXMINI    0 //Olimex Mini-Web 18f25j10 + enc28j60
#define STACK_USE_CCS_OLXWEB     1 //Olimex Pic-Web 18f452 + enc28j60
#if STACK_USE_CCS_PICENS
 #define STACK_USE_MCPENC 1
#if STACK_USE_CCS_OLXMINI
#if STACK_USE_CCS_OLXWEB
#if STACK_USE_CCS_PICEEC
 #define STACK_USE_MCPINC 1
 #include <18F4620.h>
 #use delay(clock=40M)
 #fuses H4, NOWDT, NOLVP, NODEBUG
#elif STACK_USE_CCS_PICNET
 #include <18F6722.h>
#elif STACK_USE_CCS_PICEEC
 #include <18F67J60.h>
 //#use delay(clock=41666667)
 //#fuses NOWDT, NODEBUG, H4_SW, NOIESO, NOFCMEN, PRIMARY
 #use delay(clock=25M)
 #fuses NOWDT, NODEBUG, HS, NOIESO, NOFCMEN, PRIMARY, ETHLED
#elif STACK_USE_CCS_PICNET_OLD
 #include <18F6720.h>
 #use delay(clock=20M)
 #fuses HS, NOWDT, NOLVP, NODEBUG
 #define STACK_USE_CCS_PICNET   TRUE
#elif STACK_USE_CCS_OLXMINI
 #include <18F25J10.h>
 #use delay(clock=40M, oscillator=10M)
 #fuses H4_SW, NOWDT, NODEBUG
#elif STACK_USE_CCS_OLXWEB
 #include <18F452.h>
 #use delay(clock=40000000)
 #FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
 #FUSES H4                       //High speed osc with HW enabled 4X PLL
 #FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
 #FUSES BORV20                   //Brownout reset at 2.0V
 #FUSES NOSTVREN                   //Stack full/underflow will cause reset
 #FUSES NOLVP                    //No Low Voltage Programming on B3(PIC16) or B5(PIC18)
 #FUSES NOWRTD                   //Data EEPROM not write protected
 #FUSES NOWRTB                   //Boot block not write protected
 #FUSES NOWRTC                   //configuration not registers write protected
 #FUSES NOCPB                    //No Boot Block code protection
 #FUSES NOEBTR                   //Memory not protected from table reads
 #FUSES NOEBTRB                  //Boot block not protected from table reads
 #else
 #error You need to define your custom hardware
 // There is no level-shifter (MAX3232) on the board so I could not
 // use the UART
 #use rs232(baud=9600, XMIT=PIN_A1, INVERT)
 #use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stop=1)
#else
#include "tcpip/stacktsk.c"    //include Microchip TCP/IP Stack
 #include "tcpip/mlcd.c"
 #define BUTTON1_PRESSED()  (!input(PIN_A4))
 #define USER_LED1    PIN_A5
 #define USER_LED2    PIN_B4
 #define USER_LED3    PIN_B5
 #define LED_ON       output_low
 #define LED_OFF      output_high
 #define STANDARD_ADC_STRING  "AN0"
 #define STANDARD_ADC_CHANNEL 0
 void init_user_io(void) {
   setup_adc_ports(AN0);
   *0xF92=(*0xF92 & 0xDF) | 0x11;   //a5 output, a4 and a0 input
   *0xF93=*0xF93 & 0xCF;   //b4 and b5 output
   LED_OFF(USER_LED1);
   LED_OFF(USER_LED2);
   LED_OFF(USER_LED3);
   set_adc_channel(0);
 #include "tcpip/elcd.c"
 #define USER_LED1    PIN_B3
 #define STANDARD_ADC_STRING  "AN2"
 #define STANDARD_ADC_CHANNEL 2
   setup_adc_ports(AN0_TO_AN2);
   set_adc_channel(2);
   *0xF92=*0xF92 & 0xFC;   //a0 and a1 output
   *0xF93=*0xF93 & 0xC7;   //b3, b4 and b5 output
   LED_OFF(USER_LED1);
   LED_OFF(USER_LED2);
   LED_OFF(USER_LED3);
   set_adc_channel(2);
#elif STACK_USE_CCS_OLXMINI            // JGS 2008.12.20
// #include "tcpip/elcd.c"
 #define BUTTON1_PRESSED()  (!input(PIN_B0))
 #define USER_LED1    PIN_C2
// #define STANDARD_ADC_STRING  "AN2"
// #define STANDARD_ADC_CHANNEL 2
//   setup_adc(ADC_CLOCK_INTERNAL);
//   setup_adc_ports(AN0_TO_AN2);
//   set_adc_channel(2);
//   *0xF92=*0xF92 & 0xFC;   //a0 and a1 output
//   *0xF93=*0xF93 & 0xC7;   //b3, b4 and b5 output
   LED_OFF(USER_LED1);
//   LED_OFF(USER_LED2);
//   LED_OFF(USER_LED3);
 #define USER_LED1    PIN_D5
   LED_OFF(USER_LED1);
#else
 #include "tcpip/dlcd.c"
 #define BUTTON2_PRESSED()  (!input(PIN_B1))
 #define USER_LED1    PIN_B2
   setup_adc(ADC_CLOCK_INTERNAL );
   setup_adc_ports(ANALOG_AN0_TO_AN1);
   *0xF92=*0xF92 | 3;            //a0 and a1 input (for ADC)
   *0xF93=(*0xF93 & 0xEB) | 3;   //B0 and B1 input, B2 and B4 output
   LED_OFF(USER_LED1);
   LED_OFF(USER_LED2);
   set_adc_channel(0);
void MACAddrInit(void) {
   MY_MAC_BYTE1=0;
   MY_MAC_BYTE2=2;
   MY_MAC_BYTE3=3;
   MY_MAC_BYTE4=4;
   MY_MAC_BYTE5=5;
   MY_MAC_BYTE6=6;
void IPAddrInit(void) {
   //IP address of this unit
   MY_IP_BYTE1=192;
   MY_IP_BYTE2=168;
   MY_IP_BYTE3=100;
   MY_IP_BYTE4=7;
   //network gateway
   MY_GATE_BYTE1=192;
   MY_GATE_BYTE2=168;
   MY_GATE_BYTE3=100;
   MY_GATE_BYTE4=1;
   //subnet mask
   MY_MASK_BYTE1=255;
   MY_MASK_BYTE2=255;
   MY_MASK_BYTE3=255;
   MY_MASK_BYTE4=0;
char ExampleIPDatagram[] = {
   0x45, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00,
   0x64, 0x11, 0x2A, 0x9D, 0x0A, 0x0B, 0x0C, 0x0D,
   0x0A, 0x0B, 0x0C, 0x0E
char ExampleUDPPacket[] = {
   0x04, 0x00, 0x04, 0x01, 0x00, 0x08, 0x00, 0x00,
   0x01, 0x02, 0x03, 0x04
My HARDWARE.H looks like this.
////                         HARDWARE.H                                ////
//// Hardware I/O definitions and TCP/IP stack configuration settings. ////
//// These values will probably change with each application.          ////
//// RELEASE HISTORY:                                                  ////
////    Jan 15, 2004: MODEM_RESPONSE_TIMEOUT and MODEM_CONNECT_TIMEOUT ////
////                  moved to here.                                   ////
////    Jan 09, 2004: Initial Public Release                           ////
////        (C) Copyright 1996,2004 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
#IFNDEF ___TCPIP_STACK_CONFIGURATION
#define ___TCPIP_STACK_CONFIGURATION
#ifndef STACK_USE_CCS_PICNET
#define STACK_USE_CCS_PICNET  FALSE
#ifndef STACK_USE_CCS_PICENS
#define STACK_USE_CCS_PICENS  FALSE
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#if STACK_USE_CCS_PICNET || STACK_USE_CCS_PICEEC || STACK_USE_CCS_EWL3V
 #use fast_io(F)
//// VARIOUS MODEM SETTINGS.
   #DEFINE  MODEM_DCD         PIN_G3
   #DEFINE  MODEM_RESET       PIN_G4
   #define  MODEM_TX          PIN_G1
   #define  MODEM_RX          PIN_G2
   #DEFINE  MODEM_INIT_STR    "ATM1L3&K0"   //speaker on, volume high, no hw flow control
   #DEFINE  MODEM_DIAL_STR    "ATDT"
   #DEFINE  MODEM_BAUD_RATE   115200
   #DEFINE  MODEM_RESPONSE_TIMEOUT  2000     //time to wait for a response to an AT command (in ms)
   #DEFINE  MODEM_CONNECT_TIMEOUT   120000    //time to wait for modem to make a connection (in ms)
//// VARIOUS MAC/NIC SETTINGS.
      //Latch and Directional control SFR locations for the 3 control pins
      #define NIC_RESET_LAT       LATE_RE7
      #define NIC_IOW_LAT         LATE_RE6
      #define NIC_IOR_LAT         LATE_RE5
      #define NIC_RESET_TRIS      TRISE_RE7
      #define NIC_IOW_TRIS        TRISE_RE6
      #define NIC_IOR_TRIS        TRISE_RE5
      //Latch and Directional control SFR locations for the 5bit address port
      #define NIC_ADDR_LAT        LATE
      #define NIC_ADDR_TRIS       TRISE
      //Latch, Directional and I/O SFR locations for the 8bit data port
      #define NIC_DATA_IO         PORTF
      #define NIC_DATA_LAT        LATF
      #define NIC_DATA_TRIS       TRISF
      //This macro takes an address and properly outputs it on the latch register, and sets proper pins to output.
      //Leaves other pins alone.
      #define WRITE_NIC_ADDR(a)   NIC_ADDR_LAT = (NIC_ADDR_LAT & 0xE0)|a; \
                                NIC_ADDR_TRIS = NIC_ADDR_TRIS & 0xE0
   #elif STACK_USE_CCS_PICENS
      #define PIN_ENC_MAC_SO  PIN_C4   // PIC <<<< ENC
      #define PIN_ENC_MAC_SI  PIN_C5   // PIC >>>> ENC
      #define PIN_ENC_MAC_CLK PIN_C3
      #define PIN_ENC_MAC_CS  PIN_D1
      #define PIN_ENC_MAC_RST PIN_D0
      #define PIN_ENC_MAC_INT PIN_B0
      #define PIN_ENC_MAC_WOL PIN_B1
      #define ENC_MAC_USE_SPI TRUE      //due to an errata in the ENC28J60, you should always use HW SPI to assure that SPI clock is over 8MHz!
      #define mac_enc_spi_tris_init()  TRISB=(TRISB | 0b11); TRISC = (TRISC & 0b11010111) | 0x10; TRISD=TRISD & 0xF4 //was 0xFC
      #define PIN_ENC_MAC_CS  PIN_B3
      #define PIN_ENC_MAC_RST PIN_B5
      #define PIN_ENC_MAC_INT PIN_B2
      #define mac_enc_spi_tris_init()  TRISB=(0b110); TRISC = (TRISC & 0b11010111) | 0x10; TRISD=TRISD & 0xF4//was 0xFC
      #define PIN_ENC_MAC_CS  PIN_B4
   #elif STACK_USE_CCS_EWL5V
      #define PIN_ENC_MAC_CS  PIN_A4
      #define PIN_ENC_MAC_WOL PIN_B3
      #define mac_enc_spi_tris_init()  TRISB=(TRISB | 0b00001100)&0b11011111; TRISC = (TRISC & 0b11010111) | 0x10; TRISA=TRISA & 0b11101111
   #elif STACK_USE_CCS_PICEEC||STACK_USE_CCS_EWL3V
      //no hardware definitions - everything is internal
   #else
      #error Please define your MAC/NIC I/O settings
//// SET TCP_NO_WAIT_FOR_ACK TO FALSE IF TCP STACK SHOULD WAIT FOR ACK FROM
//// REMOTE HOST BEFORE TRANSMITTING ANOTHER PACKET.  THIS MAY REDUCE THROUGHPUT.
//// DEFAULT VALUE (TRUE) GETS LOADED IN TCP.H IF THIS LINE IS REMOVED.
   #define TCP_NO_WAIT_FOR_ACK   FALSE
///DEFAULT HARDCODED IP ADDRESSES.
///  FUTURE APPLICATIONS MAY WANT TO SAVE THESE TO AN EEPROM.
///  OR USE AUTO IP ASSIGNMENT (DHCP).
///  NO TWO DEVICES ON A NETwORK CAN HAVE THE SAME IP ADDRESS
   #define MY_DEFAULT_IP_ADDR_BYTE1        10   //IP ADDRESS
   #define MY_DEFAULT_IP_ADDR_BYTE2        10   // This unit's IP address.
   #define MY_DEFAULT_IP_ADDR_BYTE3        5
   #define MY_DEFAULT_IP_ADDR_BYTE4        15
   #define MY_DEFAULT_MASK_BYTE1           0xff //NETMASK
   #define MY_DEFAULT_MASK_BYTE2           0xff // Netmask tells the IP / ARP stack which
   #define MY_DEFAULT_MASK_BYTE3           0xff // IP's are on your local network.
   #define MY_DEFAULT_MASK_BYTE4           0x00
   #define MY_DEFAULT_GATE_BYTE1           192  //GATEWAY IP ADDRESS
   #define MY_DEFAULT_GATE_BYTE2           168  // Gateway acts as a conduit between two networks.
   #define MY_DEFAULT_GATE_BYTE3           100
   #define MY_DEFAULT_GATE_BYTE4           1
///DEFAULT HARDCODED MAC ADDRESS.
///  FUTURE APPLICATIONS MAY WANT TO SAVE THIS TO AN EEPROM, OR GENERATE
///  A DYNAMIC ONE BASED UPON UNIT'S SERIAL NUMBER.
///  NO TWO DEVICES ON THE SAME ETHERNET NETWORK CAN HAVE THE SAME MAC ADDRESS.
#define MY_DEFAULT_MAC_BYTE1            0x00
#define MY_DEFAULT_MAC_BYTE2            0x04
#define MY_DEFAULT_MAC_BYTE3            0xa3
#define MY_DEFAULT_MAC_BYTE4            0x00
#define MY_DEFAULT_MAC_BYTE5            0x00
#define MY_DEFAULT_MAC_BYTE6            0x00
///Maximum sockets to be defined.
/// Note that each socket consumes 36 bytes of RAM.
/// If you remove this, a default value will be loaded in stacktsk.h
   #ifndef MAX_SOCKETS
   #define MAX_SOCKETS                     5
///Avaialble UDP Socket
/// DCHP takes 1 socket.
   #ifndef MAX_UDP_SOCKETS
   #define MAX_UDP_SOCKETS                 2
///BUFFER SIZE DEFINITIONS
/// For SLIP, there can only be one transmit and one receive buffer.
/// Both buffer must fit in one bank.  If bigger buffer is required,
/// you must manually locate tx and rx buffer in different bank
/// or modify your linker script file to support arrays bigger than
/// 256 bytes.
/// I think Microchip needs MAC_RX_BUFFER_SIZE to equal MAC_TX_BUFFER_SIZE
/// For PPP, there can only be one transmit and one receive buffer.
/// You can receive messages larger than the receive buffer if your
/// routines are fast enough.  You cannot transmit messages larger
/// than the TX buffer.  The larger the buffer you can make, the better.
/// BUG: MAC_RX_BUFFER_SIZE must equal MAC_TX_BUFFER_SIZE
/// For Ethernet, the Ethernet controler has many buffers that are
/// 1k in size.   Only one buffer is used for TX, rest are for RX.
/// Unlike SLIP and PPP, no RAM is used for these buffers.
   #if STACK_USE_MAC
       #define MAC_TX_BUFFER_SIZE          1024 //do not modify this line
       #define MAC_TX_BUFFER_COUNT         1    //do not modify this line
   #elif STACK_USE_PPP
   #elif STACK_USE_SLIP
       #define MAC_TX_BUFFER_SIZE          250
   #define MAC_RX_BUFFER_SIZE              MAC_TX_BUFFER_SIZE  //do not modify this line unless you are certain you know what you're doing
The test code looks like this:
#define STACK_USE_ICMP  1
#define STACK_USE_ARP   1
#define STACK_USE_DHCP  1
//#define MPFS_USE_PGRM 1
#include "ccstcpip.h"
#define LED pin_d5
#define DISPLAYWAIT  1     // seconds
void LCDTask(void) {
   // no LCD on mini-web so continue with serial output
   static TICKTYPE lastTick;
   static enum {LCD_Display=0, LCD_Wait=1} state=0;
   switch(state) {
      case LCD_Display:
         if (!MACIsLinked()) {
            printf("No Ethernet\n");
         else if (!DHCPIsBound()) {
            printf("DCHP Not Bound\n");
         else {
            printf("%u.%u.%u.%u\n", MY_IP_BYTE1, MY_IP_BYTE2,
               MY_IP_BYTE3, MY_IP_BYTE4);
         lastTick=TickGet();
         state=LCD_Wait;
      case LCD_Wait:
         if (TickGetDiff(TickGet(), lastTick) >= TICKS_PER_SECOND * DISPLAYWAIT)
            state=LCD_Display;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_oscillator(FALSE);
   while( 1 )
      delay_ms(100);       // allow some settle time
      printf("CCS TCP/IP TUTORIAL, EXAMPLE 11 (DHCP)\r\n");
      MACAddrInit();
       printf("MACAddrInit, done\r\n");
      StackInit();
      printf("StackInit, done\r\n");
      while(TRUE) {
         StackTask();
         LCDTask();
The problem is: afer StackTask has been called a few times the PIC will reset. Am I forgetting something? I used http://www.ccsinfo.com/forum/viewtopic.php?t=37139 as an example for my code.
Compiler version 4.088
checkout my site: www.ymoona.com/wiki
ymoona
PostPosted: Sun Jul 26, 2009 2:34 pm     Reply with quote
must be
now it works
