How does one do this? What arguments do I give on the BTFSS opcode?
somefunc(){
short sample;
#asm
BTFSS what,goes_here
#endasm
Compiler: CCS PCM C Compiler, Version 3.105
FvM
Posted: Sun Jul 19, 2009 2:36 am
Basically, BTFSS sample should do (assuming short defaults to int1).
To produce meaningful code, the next instruction should be assembly coded as well.
dbuckley
Posted: Sun Jul 19, 2009 4:23 am
And indeed that works, thank you.
Just couldn't see it...
And yes, that instruction is followed by a few others
