MILMAN Guest
| Using RTC chip as an alarm to wake up PIC |
Posted: Thu Jul 02, 2009 4:14 am |
I am building a circuit that can be programmed to 'wake up' at certain times through out the day, collect data and then go to sleep mode.
I am having a lot of trouble even setting the RTC chip to tell the correct time, and I don't really know how to deal with different months/leap years etc. I have got hold of the code below from someone who has now left the department I work in (so can't ask for help) and have modified it a bit, but to be honest I don't understand much or any of what it is really doing?
If anyone could provide a brief explanation of this or another approach to implementing the time-based data collection idea I would be very grateful. Sorry this is a bit of a vague request,
any help much appreciated,
Cheers
| Code: | byte day,month,year,hours,minutes,seconds;
void init_rtc()
i2c_start();
i2c_write(0xa0 | RTC_chip_add<<1);
i2c_write(0x00);
i2c_write(0x00);
i2c_stop();
delay_ms(11);
unsigned int get_low_bcd(unsigned int in_char) // char lower nibble to bcd
return((in_char&0x7f)-48);
separate
void set_time_and_date()
byte unitday,tenday,unitmonth,tenmonth,tenyear,unityear;
byte unithours,tenhours,unitminutes;
byte tenminutes,unitseconds,tenseconds;
unitseconds=get_low_bcd(rtc_buffer[16]);
tenseconds=get_low_bcd(rtc_buffer[15]);
unitminutes=get_low_bcd(rtc_buffer[13]);
tenminutes=get_low_bcd(rtc_buffer[12]);
unithours=get_low_bcd(rtc_buffer[10]);
tenhours=get_low_bcd(rtc_buffer[9]);
unityear=get_low_bcd(rtc_buffer[7]);
tenyear=get_low_bcd(rtc_buffer[6]);
unitmonth=get_low_bcd(rtc_buffer[4]);
tenmonth=get_low_bcd(rtc_buffer[3]);
unitday=get_low_bcd(rtc_buffer[1]);
tenday=get_low_bcd(rtc_buffer[0]);
i2c_start();
i2c_write(0x02);
i2c_write((tenseconds * 16) + unitseconds);
i2c_write((tenminutes * 16) + unitminutes);
i2c_write((tenhours * 16) + unithours);
i2c_write((unityear * 64) + (tenday * 16) + unitday);
i2c_write((tenmonth * 16) + unitmonth);
i2c_stop();
delay_ms(11);
fprintf(PC,"\f RTC written ...");
printf(lcd_putc, "\n RTC written ...");
separate
void read_time_and_date()
byte dummy;
fprintf(PC,"reading RTC from hardware...\n\r");
i2c_start();
i2c_write(0x02);
i2c_start();
i2c_write(0xa1 | RTC_chip_add<<1);
seconds = i2c_read();
minutes = i2c_read();
hours = i2c_read();
day = i2c_read();
month = i2c_read();
for(i=0;i<5;i++)
dummy = i2c_read();
i2c_stop();
delay_ms(11);
delay_ms(200);
year = ((day&0xc0)/64)&0x03;
day = (((day / 16) & 0x03) * 10) + (day & 0x0f);
month = (((month / 16) & 0x01) * 10) + (month & 0x0f);
hours = (((hours / 16) & 0x03) * 10) + (hours & 0x0f);
minutes = (((minutes / 16) & 0x0f) * 10) + (minutes & 0x0f);
seconds = (((seconds / 16) & 0x0f) * 10) + (seconds & 0x0f);
fprintf(PC,"writing RTC to monitor ...\n\r");
fprintf(PC,"year .. %3u\n\r",year);
fprintf(PC,"month .. %3u\n\r",month);
fprintf(PC,"day .. %3u\n\r",day);
fprintf(PC,"hours .. %3u\n\r",hours);
fprintf(PC,"minutes .. %3u\n\r",minutes);
fprintf(PC,"seconds .. %3u\n\r",seconds);
MILMAN Guest
Posted: Thu Jul 02, 2009 4:22 am |
| Also the RTC chip I am using is PCF8583 and using PIC16F76. Thanks. |
Posted: Thu Jul 02, 2009 10:35 am |
There is a pcf8583 driver here, though it doesn't include alarm functions:
http://www.ccsinfo.com/forum/viewtopic.php?t=27988
It has a test program, and links to schematics.
If you have any questions about the driver, ask them here in this thread
(not in the driver thread). |
MILMAN Guest
Posted: Fri Jul 03, 2009 8:39 am |
Thank you so much. That has helped me loads!
I stupidly overlooked the fact that I had set the PCF8583 i2c address to 0xA2 as well so thanks for the note. It has also highlighted that it would have been a lot better if I had used the DS1307 chip, but o well, will know in the future!
Thanks again. |
