PIC_evolution
PIC18F8722 PORT H I/O "squashes" PIN C5 signal |
Posted: Tue Jun 16, 2009 4:39 pm |
PCH V4.079
I have a stubborn issue with PORTH I/O effecting pin C5 on a PIC18F8722. C5 works fine unless any I/O on PORTH comes first. I thought it was an SPI issue, but I finally cut the code down to the following.
Code: | #include <18F8722.h>
#device ICD=TRUE
#device adc=8
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES MCU //Microcontroller Mode
#FUSES NOWAIT //Wait selections unavailable for Table Reads or Table Writes
#FUSES BW16 //16-bit external bus mode
#FUSES ABW20 //20-bit Address bus
#FUSES ECCPE //Enhanced CCP PWM outpts multiplexed with RE6 thorugh RE3
#use delay(clock=10000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
and ....
Code: | #include "main.h"
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_spi2(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
// PIN_C5 toggles (below) if this line is commented-out
// Any INPUT or OUTPUT on a PORTH pin "squashes" C5
output_high(PIN_H0);
while(1){
output_bit(PIN_C3, 1);
output_bit(PIN_C5, 1);
output_bit(PIN_B3, 1);
output_bit(PIN_C3, 0);
output_bit(PIN_C5, 0);
output_bit(PIN_B3, 0);
I have checked several boards. There are no shorts or tracking problems. In the example above C3 and B3 toggle just fine. But C5 is high at ~0.7 volts and low at 0.
Any suggestions would be very welcome (deadline looming / project stuck).
Thanks! |
Posted: Tue Jun 16, 2009 5:05 pm |
Quote: | setup_spi(SPI_SS_DISABLED);
setup_spi2(SPI_SS_DISABLED); |
Get rid of these two lines and see what happens.
If that doesn't fix it, then try a striped down program, like this:
#fuses HS,NOWDT,PUT,NOBROWNOUT,NOLVP
PIC_evolution
Posted: Tue Jun 16, 2009 8:48 pm |
Thanks PCM programmer. It turned out to be a short after all. |
