PIC18F8722 PORT H I/O "squashes" PIN C5 signal
PIC_evolution
PostPosted: Tue Jun 16, 2009 4:39 pm     Reply with quote
PCH V4.079
I have a stubborn issue with PORTH I/O effecting pin C5 on a PIC18F8722. C5 works fine unless any I/O on PORTH comes first. I thought it was an SPI issue, but I finally cut the code down to the following.
#include <18F8722.h>
#device ICD=TRUE
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES MCU                      //Microcontroller Mode
#FUSES NOWAIT                   //Wait selections unavailable for Table Reads or Table Writes
#FUSES BW16                     //16-bit external bus mode
#FUSES ABW20                    //20-bit Address bus
#FUSES ECCPE                    //Enhanced CCP PWM outpts multiplexed with RE6 thorugh RE3
#use delay(clock=10000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
and ....
#include "main.h"
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_spi2(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_4(T4_DISABLED,0,1);
   setup_vref(FALSE);
   // PIN_C5 toggles (below) if this line is commented-out
   // Any INPUT or OUTPUT on a PORTH pin "squashes" C5
   output_high(PIN_H0);
   while(1){
      output_bit(PIN_C3, 1);
      output_bit(PIN_C5, 1);
      output_bit(PIN_B3, 1);
      output_bit(PIN_C3, 0);
      output_bit(PIN_C5, 0);
      output_bit(PIN_B3, 0);
I have checked several boards. There are no shorts or tracking problems. In the example above C3 and B3 toggle just fine. But C5 is high at ~0.7 volts and low at 0.
Any suggestions would be very welcome (deadline looming / project stuck).
Thanks!
PostPosted: Tue Jun 16, 2009 5:05 pm     Reply with quote
Get rid of these two lines and see what happens.
If that doesn't fix it, then try a striped down program, like this:
#fuses HS,NOWDT,PUT,NOBROWNOUT,NOLVP
PIC_evolution
PostPosted: Tue Jun 16, 2009 8:48 pm     Reply with quote
Thanks PCM programmer. It turned out to be a short after all.
