PCD: Problem reading data from program_memory
krogers
PostPosted: Tue May 05, 2009 10:07 am     Reply with quote
I'm trying to use the program memory in a PIC24FJ128GA006 as non-volatile storage, but I'm not getting all the bytes that I write to it back from it.
Using PCD v 4.091.
void main(void) {
  char flash_read[512] = {0};
  int16 flash_size = 0;
  int1 read_from_flash = FALSE;
  // Initialize PIC configuration (set clock and pins)
  Init();
  set_timer1(0);
  enable_interrupts(int_rda);
  enable_interrupts(int_rda2);
  enable_interrupts(int_rtc);
     if(last_rcvd == '!')
       fprintf(payload, "writing %s to flash\r\n", sensor_buffer);
       flash_size = writeToFlash(sensor_buffer, sb_index);
       //write_rom_memory(FLASH_START, sensor_buffer, sb_index);
       sb_index = 0;
       sensor_buffer[0] = 0;
       read_from_flash = TRUE;
       last_rcvd = 0;
     if(read_from_flash)
        int size_read = 0;
        //fprintf(payload, "flash_size = %d\r\n", flash_size);
        size_read = readFromFlash(flash_read, flash_size);
        //read_rom_memory(FLASH_START, flash_read, flash_size);
        flash_read[size_read] = 0;
        fprintf(payload, "Read %d bytes from flash: %s\r\n", size_read, flash_read);
        flash_size = 0;
 * Writes buffer to flash for storage.  The flash on the PIC24 was designed to
 * hold 24bit instructions, and therefore converts every 4th byte to NULL
 * when being written to.  This function compensates for that to prevent data
 * loss/corruption.
 * @param buffer char pointer to the data to be written
 * @param count  int16 number of bytes to write to flash.
 * @returns number of bytes written to flash
int writeToFlash(char* buffer, int16 count)
   int16 write_count = 0;
   char write_buffer[640] = {0};
   int16 i = 0;
   erase_program_memory(FLASH_START);
   for(i = 0; i < count; i++)
      /* skip every 4th byte starting with buffer[3] */
      if(write_count != 0 && ((write_count + 1) % 4 == 0))
         write_count++;
      write_buffer[write_count++] = buffer[i];
      //fprintf(payload, "write_buffer[%d] = %d, buffer[%d] = %d\r\n", (write_count - 1), write_buffer[write_count-1], i, buffer[i]);
   write_count++;
   fprintf(payload, "writing %d bytes to flash\r\n", write_count);
   write_program_memory(FLASH_START, write_buffer, write_count);
   return write_count;
 * Reads from flash storage, skips every 4th byte to remove the NULL byte
 * written by the hardware when writing to the flash memory.
 * @param buffer char pointer for the data to be written into
 * @param count  int16 number of bytes to read from the flash.
 *               NOTE: This number is the number of bytes written to the flash
 *               INCLUDING the NULLs, not the number of bytes of data given
 *               to the writeToFlash call.
 * @returns number of bytes read without the NULL bytes.
int readFromFlash(char* buffer, int16 count)
   char read_buffer[640] = {0};
   int16 i = 0, j = 0;
   //fprintf(payload, "reading %d bytes from FLASH_START\r\n", count);
   read_program_memory(FLASH_START, read_buffer, count);
      /* skip every 4th byte starting with 3 */
      if(i != 0 && ((i + 1) % 4 == 0))
         continue;
      buffer[j++] = read_buffer[i];
      //fprintf(payload, "buffer[%d] = %d, read_buffer[%d] = %d\r\n", (j - 1), buffer[j-1], i, read_buffer[i]);
   //free(read_buffer);
   return j;
#int_rda2
void serial_isr2()
   if(sb_index > 510)
      sb_index = 0;
   sensor_buffer[sb_index] = fgetc(sensor);
   last_rcvd = sensor_buffer[sb_index];
   sb_index +=1;
   return;
Here's the output I'm getting when I run this.
Compiled on 05-May-09 at 11:39:54
writing 01234! to flash
writing 8 bytes to flash
Read 6 bytes from flash: 01234!
writing 012345! to flash
writing 10 bytes to flash
Read 8 bytes from flash: 012345
writing 0123456! to flash
writing 11 bytes to flash
Read 9 bytes from flash: 012345
writing 01234567! to flash
writing 12 bytes to flash
Read 9 bytes from flash: 01234567!
writing 012345678! to flash
writing 14 bytes to flash
Read 11 bytes from flash: 012345678
the bytes that don't show up in the read are showing up as -1 if printed as a signed decimal, which is what the flash should be erased to, as I understand it.
I'm suspecting there's some sort of word boundary issue at work here, but I can't find anything that tells me this is actually so.
FvM
PostPosted: Tue May 05, 2009 2:29 pm     Reply with quote
Apart from some minor inconsistencies in your code, e.g. no \0 delimiter set to sensor_buffer, the main problem is, that the byte count in write_program_memory() must be apparently rounded up to a multiple of four to write the data in the last word.
You can't count on the compiler doc in this regard.
