krogers
PCD: Problem reading data from program_memory |
Posted: Tue May 05, 2009 10:07 am |
I'm trying to use the program memory in a PIC24FJ128GA006 as non-volatile storage, but I'm not getting all the bytes that I write to it back from it.
Using PCD v 4.091.
void main(void) {
char flash_read[512] = {0};
int16 flash_size = 0;
int1 read_from_flash = FALSE;
// Initialize PIC configuration (set clock and pins)
Init();
set_timer1(0);
enable_interrupts(int_rda);
enable_interrupts(int_rda2);
enable_interrupts(int_rtc);
if(last_rcvd == '!')
fprintf(payload, "writing %s to flash\r\n", sensor_buffer);
flash_size = writeToFlash(sensor_buffer, sb_index);
//write_rom_memory(FLASH_START, sensor_buffer, sb_index);
sb_index = 0;
sensor_buffer[0] = 0;
read_from_flash = TRUE;
last_rcvd = 0;
if(read_from_flash)
int size_read = 0;
//fprintf(payload, "flash_size = %d\r\n", flash_size);
size_read = readFromFlash(flash_read, flash_size);
//read_rom_memory(FLASH_START, flash_read, flash_size);
flash_read[size_read] = 0;
fprintf(payload, "Read %d bytes from flash: %s\r\n", size_read, flash_read);
flash_size = 0;
* Writes buffer to flash for storage. The flash on the PIC24 was designed to
* hold 24bit instructions, and therefore converts every 4th byte to NULL
* when being written to. This function compensates for that to prevent data
* loss/corruption.
* @param buffer char pointer to the data to be written
* @param count int16 number of bytes to write to flash.
* @returns number of bytes written to flash
int writeToFlash(char* buffer, int16 count)
int16 write_count = 0;
char write_buffer[640] = {0};
int16 i = 0;
erase_program_memory(FLASH_START);
for(i = 0; i < count; i++)
/* skip every 4th byte starting with buffer[3] */
if(write_count != 0 && ((write_count + 1) % 4 == 0))
write_count++;
write_buffer[write_count++] = buffer[i];
//fprintf(payload, "write_buffer[%d] = %d, buffer[%d] = %d\r\n", (write_count - 1), write_buffer[write_count-1], i, buffer[i]);
write_count++;
fprintf(payload, "writing %d bytes to flash\r\n", write_count);
write_program_memory(FLASH_START, write_buffer, write_count);
return write_count;
* Reads from flash storage, skips every 4th byte to remove the NULL byte
* written by the hardware when writing to the flash memory.
* @param buffer char pointer for the data to be written into
* @param count int16 number of bytes to read from the flash.
* NOTE: This number is the number of bytes written to the flash
* INCLUDING the NULLs, not the number of bytes of data given
* to the writeToFlash call.
* @returns number of bytes read without the NULL bytes.
int readFromFlash(char* buffer, int16 count)
char read_buffer[640] = {0};
int16 i = 0, j = 0;
//fprintf(payload, "reading %d bytes from FLASH_START\r\n", count);
read_program_memory(FLASH_START, read_buffer, count);
/* skip every 4th byte starting with 3 */
if(i != 0 && ((i + 1) % 4 == 0))
continue;
buffer[j++] = read_buffer[i];
//fprintf(payload, "buffer[%d] = %d, read_buffer[%d] = %d\r\n", (j - 1), buffer[j-1], i, read_buffer[i]);
//free(read_buffer);
return j;
#int_rda2
void serial_isr2()
if(sb_index > 510)
sb_index = 0;
sensor_buffer[sb_index] = fgetc(sensor);
last_rcvd = sensor_buffer[sb_index];
sb_index +=1;
return;
Here's the output I'm getting when I run this.
Compiled on 05-May-09 at 11:39:54
writing 01234! to flash
writing 8 bytes to flash
Read 6 bytes from flash: 01234!
writing 012345! to flash
writing 10 bytes to flash
Read 8 bytes from flash: 012345
writing 0123456! to flash
writing 11 bytes to flash
Read 9 bytes from flash: 012345
writing 01234567! to flash
writing 12 bytes to flash
Read 9 bytes from flash: 01234567!
writing 012345678! to flash
writing 14 bytes to flash
Read 11 bytes from flash: 012345678
the bytes that don't show up in the read are showing up as -1 if printed as a signed decimal, which is what the flash should be erased to, as I understand it.
I'm suspecting there's some sort of word boundary issue at work here, but I can't find anything that tells me this is actually so. |
FvM
Posted: Tue May 05, 2009 2:29 pm |
Apart from some minor inconsistencies in your code, e.g. no \0 delimiter set to sensor_buffer, the main problem is, that the byte count in write_program_memory() must be apparently rounded up to a multiple of four to write the data in the last word.
You can't count on the compiler doc in this regard. |
