You have to change a lot more. Handling of interrupts is basically different with PIC24/30/33 and must be considered when writing a bootloader. CCS has a PCD bootloader example with the loader placed in high program memory. Personally I don't like it, cause it isn't fail safe. A protected bootloader however requires to set all interrupt vectors used in the application to fixed addresses.
Vamsi Guest
Posted: Fri Apr 03, 2009 8:05 am
Where can i find the PCD example? I dont find it in C:\Programfiles\PICC\examples.
