Converting PCH bootloader to PCD
Vamsi
PostPosted: Thu Apr 02, 2009 9:04 am     Reply with quote
I am trying to use bootloader for PIC18F for PIC24H.
Replaced RS232 pin numbers, fuses.
Replaced erase_program_eeprom to erase_program_memory (Looks like PCD doesnt support erase_program_eeprom).
#if defined(__PCM__)
   #define LOADER_SIZE   0x17F
#elif defined(__PCH__)
   #define LOADER_SIZE   0x3FF
#elif defined(__PCD__)
I get the following errors when i compile it
ERROR 126 invalid ORG range.
What am i doing wrong?
PostPosted: Thu Apr 02, 2009 3:40 pm     Reply with quote
You have to change a lot more. Handling of interrupts is basically different with PIC24/30/33 and must be considered when writing a bootloader. CCS has a PCD bootloader example with the loader placed in high program memory. Personally I don't like it, cause it isn't fail safe. A protected bootloader however requires to set all interrupt vectors used in the application to fixed addresses.
Vamsi
PostPosted: Fri Apr 03, 2009 8:05 am     Reply with quote
Where can i find the PCD example? I dont find it in C:\Programfiles\PICC\examples.
Thank you.
PostPosted: Fri Apr 03, 2009 10:24 am     Reply with quote
PICC\drivers
