problem with store the int32 variable in memory...
karthickiw
PostPosted: Wed Mar 18, 2009 11:16 pm     Reply with quote
hi friends,
I have problem with store the int32 variable in memory...I use below function to read and write int32 variable in memory...
int32 READ_INT32_EEPROM(int32 n)
   int i;
   int32 data;
   restart_wdt();
   for (i = 0; i < 4; i++)
        *(&data + i) = read_eeprom(i + n);//i
    return(data);
void WRITE_INT32_EEPROM(int32 n, int32 data)
    int32 i;
    restart_wdt();
        write_eeprom(i + n, *(&data + i) ) ;
pls check the fuction and give solution for problem..... Crying or Very sad
PostPosted: Wed Mar 18, 2009 11:52 pm     Reply with quote
Look at this CCS FAQ article:
http://www.ccsinfo.com/faq.php?page=write_eeprom_not_byte
Also, read some other forum posts, because a similar topic
was answered only a few hours ago.
In the write routine (in the link above) make these changes:
Change 'WRITE_FLOAT_EXT_EEPROM' to 'Write_int32_eeprom'
Change 'float data' to 'int32 data'
Change 'write_ext_eeprom' to 'write_eeprom'
In the read routine (in the link above) make these changes:
Change 'float READ_FLOAT_EXT_EEPROM' to 'int32 read_int32_eeprom'
Change 'read_ext_eeprom' to 'read_eeprom'
The eeprom address must be increased by 4 bytes, each time you
write a new int32 value.
karthickiw
thank you...
PostPosted: Thu Mar 19, 2009 7:29 am     Reply with quote
thank you... its work Laughing
