karthickiw
problem with store the int32 variable in memory... |
Posted: Wed Mar 18, 2009 11:16 pm |
hi friends,
I have problem with store the int32 variable in memory...I use below function to read and write int32 variable in memory...
int32 READ_INT32_EEPROM(int32 n)
int i;
int32 data;
restart_wdt();
for (i = 0; i < 4; i++)
*(&data + i) = read_eeprom(i + n);//i
return(data);
void WRITE_INT32_EEPROM(int32 n, int32 data)
int32 i;
restart_wdt();
write_eeprom(i + n, *(&data + i) ) ;
pls check the fuction and give solution for problem..... ![Crying or Very sad](images/smiles/icon_cry.gif) |
Posted: Wed Mar 18, 2009 11:52 pm |
Look at this CCS FAQ article:
http://www.ccsinfo.com/faq.php?page=write_eeprom_not_byte
Also, read some other forum posts, because a similar topic
was answered only a few hours ago.
In the write routine (in the link above) make these changes:
Quote: |
Change 'WRITE_FLOAT_EXT_EEPROM' to 'Write_int32_eeprom'
Change 'float data' to 'int32 data'
Change 'write_ext_eeprom' to 'write_eeprom'
In the read routine (in the link above) make these changes:
Quote: |
Change 'float READ_FLOAT_EXT_EEPROM' to 'int32 read_int32_eeprom'
Change 'read_ext_eeprom' to 'read_eeprom'
The eeprom address must be increased by 4 bytes, each time you
write a new int32 value. |
karthickiw
thank you... |
Posted: Thu Mar 19, 2009 7:29 am |
thank you... its work ![Laughing](images/smiles/icon_lol.gif) |
