Does get_timer1() conflict with Timer1 Interrupt |
Posted: Thu Mar 05, 2009 9:59 pm |
I found out that my processor has two timers, TIMER0 and TIMER1, but I can use only Timer1 since TOCKI is used for GPIO function.
So can I disable INT_TIMER1 before it needs to check timeout wtih set_timer1(0) and get_timer1() and enable INT_TIMER1 back after checking timeout event is finished?
#include <16F689.h>
#include <stdio.h>
#include <stdlib.h>
#use delay(clock=3686400, crystal)
#use rs232(baud=115200, xmit=PIN_B7, rcv=PIN_B5)
#fuses XT, NOWDT, PUT, MCLR, NOPROTECT, NOCPD, NOBROWNOUT, NOIESO, NOFCMEN
unsigned int16 x;
#INT_TIMER1
void timer1_isr(void)
set_timer1(0x1F00); //500ms
EVENT_1();
setup_timer_1( T1_INTERNAL | T1_DIV_BY_8);
enable_interrupts(global);
disable_interrupts(INT_TIMER1);
set_timer1(0);
EVENT_2();
x = get_timer1();
Thanks. |
Posted: Thu Mar 05, 2009 10:05 pm |
What happened to putting Timer1 questions all in one thread, rather than
a bunch of scattered posts ? |
boulder
Posted: Thu Mar 05, 2009 10:16 pm |
Since my questions are different about Timer1, I do not want to confuse people. I am sorry about this. |
