Does get_timer1() conflict with Timer1 Interrupt
PostPosted: Thu Mar 05, 2009 9:59 pm     Reply with quote
I found out that my processor has two timers, TIMER0 and TIMER1, but I can use only Timer1 since TOCKI is used for GPIO function.
So can I disable INT_TIMER1 before it needs to check timeout wtih set_timer1(0) and get_timer1() and enable INT_TIMER1 back after checking timeout event is finished?
#include <16F689.h>
#include <stdio.h>
#include <stdlib.h>
#use delay(clock=3686400, crystal)
#use rs232(baud=115200, xmit=PIN_B7, rcv=PIN_B5)
#fuses XT, NOWDT, PUT, MCLR, NOPROTECT, NOCPD, NOBROWNOUT, NOIESO, NOFCMEN
unsigned int16 x;
#INT_TIMER1
void timer1_isr(void)
    set_timer1(0x1F00);    //500ms
    EVENT_1();
  setup_timer_1( T1_INTERNAL | T1_DIV_BY_8);
  enable_interrupts(global);
     disable_interrupts(INT_TIMER1);
     set_timer1(0);
     EVENT_2();
     x = get_timer1();
Thanks.
PostPosted: Thu Mar 05, 2009 10:05 pm     Reply with quote
What happened to putting Timer1 questions all in one thread, rather than
a bunch of scattered posts ?
boulder
PostPosted: Thu Mar 05, 2009 10:16 pm     Reply with quote
Since my questions are different about Timer1, I do not want to confuse people. I am sorry about this.
