MarkR Guest
concatenate defined strings for #export |
Posted: Wed Feb 18, 2009 11:23 am |
Hi
QUESTION1
I wish to concatenate multiple #define strings and then use the result in the #export filename
Code: | #define FNAMEA "PART A"
#define FNAMEB "PART B"
#define FNAMEC "PART C"
#EXPORT (FILE=FNAMEA+FNAMEB+FNAMEC, HEX) |
I always end up with just FNAMEA
QUESTION2
If I have a comma in the filename in export then compile fails (in a quite bizarre and unexpected way!)
Code: | #EXPORT (FILE="myName, version1.hex", HEX) |
If anyone can help, thanks. |
