Torello
#byte access of FSR0H / FSR0L |
Posted: Fri Oct 23, 2009 8:07 am |
Does any body know why the compiler clears FSR0H when loading FSR0L ? First I though it might be a odd/even adress thing but if I do the same loading on for example ADCON1/2 then it does it OK...
#byte FSR0H = 0xFEA
#byte FSR0L = 0xFE9
#byte ADCON1 = 0xfc1
#byte ADCON2 = 0xfc0
.................... FSR0H = 0x11;
00212: MOVLW 11
00214: MOVWF FEA
.................... FSR0L = 0x22;
00216: CLRF FEA <<< OUCH! WHY????
00218: MOVLW 22
0021A: MOVWF FE9
.................... AdCON2 = 0x55;
0021C: MOVLW 55
0021E: MOVWF FC0
.................... ADCON1 = 0x44;
00220: MOVLW 44
00222: MOVWF FC1
regards,
Edwin.
Compiler version PCWHD 4.099 |
Posted: Fri Oct 23, 2009 2:12 pm |
The quick solution is just to change the order of the lines. |
Torello
Posted: Fri Oct 23, 2009 4:03 pm |
I though of that solution too. But knowing -why- it is done give me more confidence that this solution stays working in the future....
A support request on this issue has been submitted to CCS.
(any thoughts are of course still welcome) |
Posted: Sat Oct 24, 2009 2:56 am |
I think you will find the reason is that the compiler already has a _16bit_ variable, called 'FSR0L' defined.
The #byte directive works in two different ways. If no variable exists with the name being used, it created an 8bit variable, and maps it to the defined address. If a variable already exists with the name, it maps this variable to the address.
So the compiler already has a 16bit variable called FSR0L defined, and when it sees the #byte directive, maps _this_ to the address. Hence when you access FSR0L, it accesses both addresses. Two solutions:
1) Use your own name to avoid any possible clash with the compiler 'My_FSR0L' for example.
2) Assume that the compiler's FSR0L, does not 'mind' being at the FSR address, and use:
#byte FSR0L = 0xFE9
FSR0L = 0x1122;
Torello
Posted: Tue Oct 27, 2009 9:27 am |
Were is this _16bit_ applied on the definitions of Fsr's?
Solution 1 does -not- work:
.................... My_fsr0H = make8(Dbf,1);
00342: MOVFF 213,FEA
.................... My_fsr0L = make8(Dbf,0);
00346: MOVF x12,W
00348: CLRF FEA
0034A: MOVWF FE9
Solution 2 to be used
Thanks,
Edwin |
