#byte access of FSR0H / FSR0L
Torello
PostPosted: Fri Oct 23, 2009 8:07 am     Reply with quote
Does any body know why the compiler clears FSR0H when loading FSR0L ? First I though it might be a odd/even adress thing but if I do the same loading on for example ADCON1/2 then it does it OK...
#byte  FSR0H   = 0xFEA
#byte  FSR0L   = 0xFE9
#byte ADCON1   = 0xfc1
#byte ADCON2   = 0xfc0
....................   FSR0H = 0x11;
00212:  MOVLW  11
00214:  MOVWF  FEA
....................   FSR0L = 0x22;
00216:  CLRF   FEA                       <<< OUCH! WHY????
00218:  MOVLW  22
0021A:  MOVWF  FE9
....................   AdCON2 = 0x55;
0021C:  MOVLW  55
0021E:  MOVWF  FC0
....................   ADCON1 = 0x44;
00220:  MOVLW  44
00222:  MOVWF  FC1
regards,
Edwin.
Compiler version PCWHD 4.099
PostPosted: Fri Oct 23, 2009 2:12 pm     Reply with quote
The quick solution is just to change the order of the lines.
Torello
PostPosted: Fri Oct 23, 2009 4:03 pm     Reply with quote
I though of that solution too. But knowing -why- it is done give me more confidence that this solution stays working in the future....
A support request on this issue has been submitted to CCS.
(any thoughts are of course still welcome)
PostPosted: Sat Oct 24, 2009 2:56 am     Reply with quote
I think you will find the reason is that the compiler already has a _16bit_ variable, called 'FSR0L' defined.
The #byte directive works in two different ways. If no variable exists with the name being used, it created an 8bit variable, and maps it to the defined address. If a variable already exists with the name, it maps this variable to the address.
So the compiler already has a 16bit variable called FSR0L defined, and when it sees the #byte directive, maps _this_ to the address. Hence when you access FSR0L, it accesses both addresses. Two solutions:
1) Use your own name to avoid any possible clash with the compiler 'My_FSR0L' for example.
2) Assume that the compiler's FSR0L, does not 'mind' being at the FSR address, and use:
#byte  FSR0L   = 0xFE9
   FSR0L = 0x1122;
Torello
PostPosted: Tue Oct 27, 2009 9:27 am     Reply with quote
Were is this _16bit_ applied on the definitions of Fsr's?
Solution 1 does -not- work:
....................   My_fsr0H = make8(Dbf,1);
00342:  MOVFF  213,FEA
....................   My_fsr0L = make8(Dbf,0);
00346:  MOVF   x12,W
00348:  CLRF   FEA
0034A:  MOVWF  FE9
Solution 2 to be used Very Happy
Thanks,
Edwin
