Need Help! Fuse problem
PostPosted: Sat Dec 27, 2008 12:04 pm     Reply with quote
Why this code does not work ?
#include <30F4013.h>
#fuses PR,HS,NOCKSFSM ,NOWDT
#FUSES NOWDT,NOPROTECT,NODEBUG,NOWRT,NOPROTECT,NOCOE,BORV42,BROWNOUT,NOPUT
#use delay(clock=20000000, RESTART_WDT)
delay_ms(200);
   while (TRUE) {
     output_high(PIN_B0);
     delay_ms(200);
     output_low(PIN_B0);
     delay_ms(200);
When I use internal RC oscillator (FRC) then LED on pin PB0 blinking.
I guess, the #fuses HS is not set property.
I use CCS compiler version 4.084
Sorry for my bad english.
Thank you
Re: Need Help! Fuse problem
PostPosted: Sat Dec 27, 2008 12:49 pm     Reply with quote
delay_ms(200);
   while (TRUE) {
     delay_ms(200);
     output_low(PIN_B0);
     delay_ms(200);
Thank you
PROBLEM SOLVED (micro short-circuit on PCB OSC2 pin and RC13)
Thank you
