Need Help! Fuse problem |
Posted: Sat Dec 27, 2008 12:04 pm |
Why this code does not work ?
Code: | #include <30F4013.h>
#fuses PR,HS,NOCKSFSM ,NOWDT
#FUSES NOWDT,NOPROTECT,NODEBUG,NOWRT,NOPROTECT,NOCOE,BORV42,BROWNOUT,NOPUT
#use delay(clock=20000000, RESTART_WDT)
delay_ms(200);
while (TRUE) {
output_high(PIN_B0);
delay_ms(200);
output_low(PIN_B0);
delay_ms(200);
When I use internal RC oscillator (FRC) then LED on pin PB0 blinking.
I guess, the #fuses HS is not set property.
I use CCS compiler version 4.084
Sorry for my bad english.
Thank you |
Re: Need Help! Fuse problem |
Posted: Sat Dec 27, 2008 12:49 pm |
Anonymous wrote: | Why this code does not work ?
delay_ms(200);
while (TRUE) {
delay_ms(200);
output_low(PIN_B0);
delay_ms(200);
Thank you |
PROBLEM SOLVED (micro short-circuit on PCB OSC2 pin and RC13)
Thank you |
