accelerometer-LED problem, perhaps obvious
elmoss
PostPosted: Fri Nov 28, 2008 12:01 am     Reply with quote
I'm attempting to read the pulse width from a digital accelerometer, and use the values to set the duty cycles of some LEDs for color blending. Timer0 is a state machine that on sequential calls adjusts the duty cycle values and cycles the LEDs on and off. The main function measures the pulse width (fixed period of 10ms) and doesn't yet use it to assign anything. The incoming values will eventually be used to set the acc values, but for now I set those directly for testing purposes. The problem is the LEDs do not respond to changes in the acc values. Is there an obvious mistake here? I'm somewhat a newbie, so it's possible the answer is pretty basic and obvious. Anybody have any ideas? Gratefully appreciated!
#include "C:\Program Files\PICC\Projects\tiltydigital.h"
#define Yin pin_c2
#define Xin pin_c3
unsigned int timerMode, Racc, Rduty, Bacc, Bduty, Gacc, Gduty, lightcounter, durationCounter, Yval, Xval;
void waitForRise(int channel);
#int_TIMER0
void  TIMER0_isr(void)
   if (timerMode == 0){//change Rduty
      if (Racc>Rduty)
         Rduty++;
         Rduty--;
      timerMode = 1;
   else if (timerMode == 1){//change Bduty
      if (Bacc>Bduty)
         Bduty++;
         Bduty--;
      timerMode = 2;
   else if (timerMode == 2){//change Gduty
      if (Gacc>Gduty)
         Gduty++;
         Gduty--;
      timerMode = 3;
   else if (timerMode == 3){//control R output
      if (Rduty>lightcounter)
         output_high(pin_a0);
         output_low(pin_a0);
      timerMode = 4;
   else if (timerMode == 4){//control G output
      if (Gduty>lightcounter)
         output_high(pin_a1);
         output_low(pin_a1);
      timerMode = 5;
   else if (timerMode == 5){//control B output
         output_high(pin_a2);
         output_low(pin_a2);
      timerMode = 0;
      lightcounter++;
   setup_adc(ADC_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
//   setup_wdt(WDT_18MS|WDT_DIV_16);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(OSC_4MHZ);
   // TODO: USER CODE!!
   timerMode = 0;
   lightcounter = 0;
   while(1){
      Bacc = 5;
      Racc = 5;
      Gacc = 5;
      durationCounter = 0;
      waitForRise(1);
      while(input(Yin)){
         durationCounter++;
         delay_us(100);
      Yval = durationCounter;
      waitForRise(2);
      while(input(Xin)){
         durationCounter++;
         delay_us(100);
      Xval = durationCounter;
}//main
void waitForRise(int channel){
   if (channel == 1){
      while(input(Yin));
      while(!input(Yin));
   else if (channel == 2){
      while(input(Xin));
      while(!input(Xin));
PostPosted: Fri Nov 28, 2008 1:55 pm     Reply with quote
Post your:
1. PIC
2. #fuses statement.
3. #use delay() statement.
4. Compiler version.
elmoss
PostPosted: Fri Nov 28, 2008 2:02 pm     Reply with quote
my mistake! here's the info:
1. PIC: 16f684
2.
#include <16F684.h>
#device adc=8
#FUSES WDT                      //Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
4. Compiler version: 4.038
PostPosted: Fri Nov 28, 2008 2:54 pm     Reply with quote
#FUSES WDT
The Watchdog timer is enabled, but you're not restarting it in your code,
so the PIC will keep resetting. Change it to NOWDT.
If that doesn't fix the problem, then strip down your program so it only
uses one LED (such as the Red LED).
