elmoss
accelerometer-LED problem, perhaps obvious |
Posted: Fri Nov 28, 2008 12:01 am |
I'm attempting to read the pulse width from a digital accelerometer, and use the values to set the duty cycles of some LEDs for color blending. Timer0 is a state machine that on sequential calls adjusts the duty cycle values and cycles the LEDs on and off. The main function measures the pulse width (fixed period of 10ms) and doesn't yet use it to assign anything. The incoming values will eventually be used to set the acc values, but for now I set those directly for testing purposes. The problem is the LEDs do not respond to changes in the acc values. Is there an obvious mistake here? I'm somewhat a newbie, so it's possible the answer is pretty basic and obvious. Anybody have any ideas? Gratefully appreciated!
#include "C:\Program Files\PICC\Projects\tiltydigital.h"
#define Yin pin_c2
#define Xin pin_c3
unsigned int timerMode, Racc, Rduty, Bacc, Bduty, Gacc, Gduty, lightcounter, durationCounter, Yval, Xval;
void waitForRise(int channel);
#int_TIMER0
void TIMER0_isr(void)
if (timerMode == 0){//change Rduty
if (Racc>Rduty)
Rduty++;
Rduty--;
timerMode = 1;
else if (timerMode == 1){//change Bduty
if (Bacc>Bduty)
Bduty++;
Bduty--;
timerMode = 2;
else if (timerMode == 2){//change Gduty
if (Gacc>Gduty)
Gduty++;
Gduty--;
timerMode = 3;
else if (timerMode == 3){//control R output
if (Rduty>lightcounter)
output_high(pin_a0);
output_low(pin_a0);
timerMode = 4;
else if (timerMode == 4){//control G output
if (Gduty>lightcounter)
output_high(pin_a1);
output_low(pin_a1);
timerMode = 5;
else if (timerMode == 5){//control B output
output_high(pin_a2);
output_low(pin_a2);
timerMode = 0;
lightcounter++;
setup_adc(ADC_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
// setup_wdt(WDT_18MS|WDT_DIV_16);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_4MHZ);
// TODO: USER CODE!!
timerMode = 0;
lightcounter = 0;
while(1){
Bacc = 5;
Racc = 5;
Gacc = 5;
durationCounter = 0;
waitForRise(1);
while(input(Yin)){
durationCounter++;
delay_us(100);
Yval = durationCounter;
waitForRise(2);
while(input(Xin)){
durationCounter++;
delay_us(100);
Xval = durationCounter;
}//main
void waitForRise(int channel){
if (channel == 1){
while(input(Yin));
while(!input(Yin));
else if (channel == 2){
while(input(Xin));
while(!input(Xin));
Posted: Fri Nov 28, 2008 1:55 pm |
Post your:
1. PIC
2. #fuses statement.
3. #use delay() statement.
4. Compiler version. |
elmoss
Posted: Fri Nov 28, 2008 2:02 pm |
my mistake! here's the info:
1. PIC: 16f684
2. Code: | #include <16F684.h>
#device adc=8
#FUSES WDT //Watch Dog Timer
#FUSES NOFCMEN //Fail-safe clock monitor disabled
4. Compiler version: 4.038 |
Posted: Fri Nov 28, 2008 2:54 pm |
The Watchdog timer is enabled, but you're not restarting it in your code,
so the PIC will keep resetting. Change it to NOWDT.
If that doesn't fix the problem, then strip down your program so it only
uses one LED (such as the Red LED). |
