		| Author | Message |
		| james Guest
				| rs232 on 18f4520 |
				|  Posted: Tue Nov 18, 2008 4:02 pm |   |
				| Hi, looking for some pointers / things to check with a problem I have. I'm running rs232 via max3232 on and 18f4520.
 I have a basic program running, and can send from the pic to hyper-terminal (windows).
 When I try and send something back from hyper-terminal, then return it via the pic to ensure both tx and rx work, I get hieroglyphics back... i.e, when I send a key press from the keyboard back to the pic, I used getc command, assign data to a char, then do a printf, and get junk back at the hyper terminal.
 any ideas?
 thanks
 james
		| PCM programmer
				|  Posted: Tue Nov 18, 2008 4:14 pm |   |
				| Try a simple test program, as shown below.    If your crystal is above 4 MHz, then change the fuse from XT to HS and also edit the #use delay
 statement for the correct frequency.
  	  | Code: |  	  | #include <18F4520.H>
 #fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
 int8 c;
 printf("Start: \n\r");
 c = getc();
 putc(c);
		| james Guest
				|  Posted: Tue Nov 18, 2008 4:17 pm |   |
				| Thanks for your very quick reply, I am unable to test anything until Thursday, am away from the workshop,
 Thanks for your help so far and I will post again after I tried your suggestion.
 Thank you again.
 James
		| asmallri
				|  Posted: Tue Nov 18, 2008 4:41 pm |   |
				| check the baud rate, number of start bits, data bits, stop bits and parity match. Most text type applications use 1 start, 1 stop, 8 data, no parity.
 If you are using your own hardware then check that the max chip is generating the +10 and -10 volt levels. When the PIC is not transmitting you should be able to measure -10 volts on the transmit output from the MAX chip to the PC
 Regards, Andrew
 | You cannot post new topics in this forum You cannot reply to topics in this forum
