james Guest
rs232 on 18f4520 |
Posted: Tue Nov 18, 2008 4:02 pm |
Hi, looking for some pointers / things to check with a problem I have.
I'm running rs232 via max3232 on and 18f4520.
I have a basic program running, and can send from the pic to hyper-terminal (windows).
When I try and send something back from hyper-terminal, then return it via the pic to ensure both tx and rx work, I get hieroglyphics back... i.e, when I send a key press from the keyboard back to the pic, I used getc command, assign data to a char, then do a printf, and get junk back at the hyper terminal.
any ideas?
thanks
james |
Posted: Tue Nov 18, 2008 4:14 pm |
Try a simple test program, as shown below. If your crystal is above
4 MHz, then change the fuse from XT to HS and also edit the #use delay
statement for the correct frequency.
#include <18F4520.H>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
int8 c;
printf("Start: \n\r");
c = getc();
putc(c);
james Guest
Posted: Tue Nov 18, 2008 4:17 pm |
Thanks for your very quick reply,
I am unable to test anything until Thursday, am away from the workshop,
Thanks for your help so far and I will post again after I tried your suggestion.
Thank you again.
James |
asmallri
Posted: Tue Nov 18, 2008 4:41 pm |
check the baud rate, number of start bits, data bits, stop bits and parity match. Most text type applications use 1 start, 1 stop, 8 data, no parity.
If you are using your own hardware then check that the max chip is generating the +10 and -10 volt levels. When the PIC is not transmitting you should be able to measure -10 volts on the transmit output from the MAX chip to the PC _________________ Regards, Andrew
