		| Author | Message |
		| nicotec
				| Hardware PWM 50Hz using PIC24FJ16GA002 |
				|  Posted: Thu Nov 13, 2008 1:18 pm |   |
				| Hi, I'm new to use CCS compiler and I have some difficulty to obtain through pic24-wizard the hardware pwm in subject. Here is the code:
  	  | Code: |  	  | void main() {
 #pin_select OC1  = PIN_B4
 setup_compare(1,COMPARE_PWM | COMPARE_TIMER2 );
 setup_timer2(TMR_INTERNAL | TMR_DIV_BY_64,20 );
 setup_spi(SPI_SS_DISABLED);
 setup_spi2(SPI_SS_DISABLED);
 setup_wdt(WDT_ON);
 setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
 // TODO: USER CODE!!
 Through pic24-wizard appear that the following line:
  	  | Code: |  	  | setup_compare(1,COMPARE_PWM | COMPARE_TIMER2 );
 It should be enough to obtain hardware pwm, but the frequency specified during wizard setup does not appear in the code.
 Thank You in advance and Regards
		| FvM
				|  Posted: Thu Nov 13, 2008 5:10 pm |   |
				| The PWM period of 20 seems a bit too short (and doesn't allow any usable PWM operation). You didn't tell the system clock frequency, |  |
		| nicotec
				| clock |
				|  Posted: Fri Nov 14, 2008 1:24 am |   |
				| Internal FRC 8Mhz; could you help me? Thanks
		| FvM
				|  Posted: Fri Nov 14, 2008 1:20 pm |   |
				| According to documentation, setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,10000) should give 50 Hz PWM frequenc. |  |
		| nicotec
				| PWM |
				|  Posted: Fri Nov 14, 2008 2:52 pm |   |
				| Thank You very much, I calculated a PR2 of 9999 using data sheet formula; I'll try on monday the following setting to obtain a 50Hz 50% PWM:
  	  | Code: |  	  | #pin_select OC1  = PIN_B4
 setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,9999);
 set_pwm_duty(1,32768);
 after I will post result here;
 I hope it will work fine.
 Bye
		| nicotec
				|  Posted: Mon Nov 17, 2008 1:20 am |   |
				| I tried the above line but still not working; here is my code:
 setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,9999 );
 setup_wdt(WDT_ON);
 output_low(PIN_B8);
 do
 output_high(PIN_B6);
 output_low(PIN_B6);
 output_high(PIN_B7);
 output_low(PIN_B7);
 } while(true);
		| FvM
				|  Posted: Mon Nov 17, 2008 3:55 pm |   |
				| With PMW duty cycle set to a value higher than timer2 register, PWM should be expected to stay permanently high. |  |
