Hardware PWM 50Hz using PIC24FJ16GA002
nicotec
PostPosted: Thu Nov 13, 2008 1:18 pm     Reply with quote
Hi, I'm new to use CCS compiler and I have some difficulty to obtain through pic24-wizard the hardware pwm in subject.
Here is the code:
   #pin_select OC1  = PIN_B4
   setup_compare(1,COMPARE_PWM | COMPARE_TIMER2 );
   setup_timer2(TMR_INTERNAL | TMR_DIV_BY_64,20 );
   setup_spi(SPI_SS_DISABLED);
   setup_spi2(SPI_SS_DISABLED);
   setup_wdt(WDT_ON);
   setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   // TODO: USER CODE!!
Through pic24-wizard appear that the following line:
It should be enough to obtain hardware pwm, but the frequency specified during wizard setup does not appear in the code.
Thank You in advance and Regards
FvM
PostPosted: Thu Nov 13, 2008 5:10 pm     Reply with quote
The PWM period of 20 seems a bit too short (and doesn't allow any usable PWM operation). You didn't tell the system clock frequency,
nicotec
clock
PostPosted: Fri Nov 14, 2008 1:24 am     Reply with quote
Internal FRC 8Mhz; could you help me?
FvM
PostPosted: Fri Nov 14, 2008 1:20 pm     Reply with quote
According to documentation, setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,10000) should give 50 Hz PWM frequenc.
nicotec
PWM
PostPosted: Fri Nov 14, 2008 2:52 pm     Reply with quote
Thank You very much, I calculated a PR2 of 9999 using data sheet formula; I'll try on monday the following setting to obtain a 50Hz 50% PWM:
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,9999);
set_pwm_duty(1,32768);
after I will post result here;
I hope it will work fine.
Bye
nicotec
PostPosted: Mon Nov 17, 2008 1:20 am     Reply with quote
I tried the above line but still not working; here is my code:
   setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,9999 );
   setup_wdt(WDT_ON);
   output_low(PIN_B8);
   do
   output_high(PIN_B6);
   output_low(PIN_B6);
   output_high(PIN_B7);
   output_low(PIN_B7);
   } while(true);
FvM
PostPosted: Mon Nov 17, 2008 3:55 pm     Reply with quote
With PMW duty cycle set to a value higher than timer2 register, PWM should be expected to stay permanently high.
