keypad problem
shroder300
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
keypad problem
PostPosted: Thu Nov 13, 2008 10:29 am     Reply with quote
First my keypad is a 4x4 matrix keypad with an extra common pin. I have it hooked to portb with pullups active. Upon a button press I get a col and row pin shorted to gnd indicating which button is pressed. I took newguy's interrupt code (http://www.ccsinfo.com/forum/viewtopic.php?t=19726) and modified it.
What I get is the button code press and then release. But I have to hold down the button to get the push and release code. If I quickly tap the key I only get the release code.
Is my keypad (all electronics) bad or my code wrong?
pic16f877a keypad routine.                                              11/12/08
Jason Berkhimer
Keypad from all electronics. 4 col pins, 4 row pins and common. col and row
connected to portb and common to gnd. pullups active. keypad press detected
through interrupts.
#include <16F877A.h>
#fuses HS           // fast oscillator
#fuses NOWDT      // no watch dog timer
#fuses NOPROTECT   // no code protection
#fuses NODEBUG      // no debugger
#fuses NOPUT      // no power up timer
#fuses NOBROWNOUT   // no brown out reset
#fuses NOLVP      // no low voltage programming
#fuses NOCPD      // no EE memory protection
#fuses NOWRT      //
#byte porta = 0x05
#byte portb = 0x06
#byte portc = 0x07
#byte portd = 0x08
#byte porte = 0x09
#use fast_io(B)
// #include <stdlib.h>
// variables ===================================================================
int1 key_pressed = FALSE;
static int old_b_state, new_b_state;
static int16 key = 0;
char kchar;
// interrupts ==================================================================
#int_RB
void RB_isr(void) {
   new_b_state = input_b();
   if (old_b_state != new_b_state) {
      old_b_state = input_b();
//      if (old_b_state == 0xff)
         key_pressed = TRUE;
// functions ===================================================================
void find_key(void) {
   int pin, b_state, delay = 10;
   disable_interrupts(INT_RB);
   delay_ms(50);  // debounce
   b_state = portb;
   printf("%X",b_state);
   old_b_state=input_b();
   enable_interrupts(INT_RB);
// main ========================================================================
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   port_b_pullups(TRUE);
   delay_us(50);         //wait for pullups to come on.
   set_tris_b(0xff);
   old_b_state = input_b();       //read portb before turning on int.
   enable_interrupts(global);
   printf("keypad test");
      if (key_pressed) {
         find_key();
      output_d(0x0);
      delay_ms(250);
      output_d(0x2);
      delay_ms(250);
compiler PCM version 4.064
Wayne_
PostPosted: Thu Nov 13, 2008 10:56 am     Reply with quote
I would start by changing this
void RB_isr(void) {
   if (old_b_state != new_b_state) { <---- Not required as this interrupted due to a change in state!
         key_pressed = TRUE;
change to
void RB_isr(void) {
  if (old_b_state == 0xFF)
    key_pressed = true;
You don't actually use the push code ?
I can't see what your problem is!
shroder300
PostPosted: Thu Nov 13, 2008 11:09 am     Reply with quote
Right now I am only printing the codes to the serial port.
My problem is the keypad buttons have to be held down for at least half a second before the program prints a press code and then release code (once the button is released). If I don't hold down the button I only get a release code on the serial port.
The changes you suggested didn't change the results at all.
PostPosted: Thu Nov 13, 2008 2:00 pm     Reply with quote
Look at this CCS example file on using push buttons with #int_rb:
c:\program files\picc\examples\ex_pbutt.c
It has an example of how to do the isr (for 'press' or 'release' but not both).
Your complaint about the requirement for a 500ms hold down time is
caused by the delays in your loop. Your program only tests the status
every 1/2 second. That's the update rate.
PostPosted: Fri Nov 14, 2008 5:54 am     Reply with quote
thanks, I didnt think about that. Embarassed should I be checking the status in the isr instead?
shroder300
PostPosted: Fri Nov 14, 2008 10:21 am     Reply with quote
Here is my final code. the int routine will pick up both a press and a release. the main function will only print a press, however.
Jason Berkhimer
keypad from all electronics. 4 col pins, 4 row pins and common. col and row
through interrupts. prints raw data from keypad to serial port and portd
#fuses NOWRT      //
#byte porta = 0x05
#byte portb = 0x06
#byte portc = 0x07
#byte portd = 0x08
#byte porte = 0x09
#use fast_io(B)
#use fast_io(D)
char kchar;
#int_RB
void RB_isr(void) {          // detects both press and release
      if (new_b_state != old_b_state);   // make sure state changed
         key_pressed = TRUE;
      old_b_state=new_b_state;
   b_state = portb;
   if (b_state != 0xff){      // only print on press
      printf("-%X-",b_state);
      output_d(b_state);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   delay_us(50);         // wait for pullups to come on.
   set_tris_b(0xff);
   set_tris_d(0x00);
   set_tris_c(0x00);
   old_b_state = input_b();       // read portb before turning on int.
      if (key_pressed) {
         find_key();
