shroder300
keypad problem |
Posted: Thu Nov 13, 2008 10:29 am |
First my keypad is a 4x4 matrix keypad with an extra common pin. I have it hooked to portb with pullups active. Upon a button press I get a col and row pin shorted to gnd indicating which button is pressed. I took newguy's interrupt code (http://www.ccsinfo.com/forum/viewtopic.php?t=19726) and modified it.
What I get is the button code press and then release. But I have to hold down the button to get the push and release code. If I quickly tap the key I only get the release code.
Is my keypad (all electronics) bad or my code wrong?
pic16f877a keypad routine. 11/12/08
Jason Berkhimer
Keypad from all electronics. 4 col pins, 4 row pins and common. col and row
connected to portb and common to gnd. pullups active. keypad press detected
through interrupts.
#include <16F877A.h>
#fuses HS // fast oscillator
#fuses NOWDT // no watch dog timer
#fuses NOPROTECT // no code protection
#fuses NODEBUG // no debugger
#fuses NOPUT // no power up timer
#fuses NOBROWNOUT // no brown out reset
#fuses NOLVP // no low voltage programming
#fuses NOCPD // no EE memory protection
#fuses NOWRT //
#byte porta = 0x05
#byte portb = 0x06
#byte portc = 0x07
#byte portd = 0x08
#byte porte = 0x09
#use fast_io(B)
// #include <stdlib.h>
// variables ===================================================================
int1 key_pressed = FALSE;
static int old_b_state, new_b_state;
static int16 key = 0;
char kchar;
// interrupts ==================================================================
#int_RB
void RB_isr(void) {
new_b_state = input_b();
if (old_b_state != new_b_state) {
old_b_state = input_b();
// if (old_b_state == 0xff)
key_pressed = TRUE;
// functions ===================================================================
void find_key(void) {
int pin, b_state, delay = 10;
disable_interrupts(INT_RB);
delay_ms(50); // debounce
b_state = portb;
printf("%X",b_state);
old_b_state=input_b();
enable_interrupts(INT_RB);
// main ========================================================================
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
port_b_pullups(TRUE);
delay_us(50); //wait for pullups to come on.
set_tris_b(0xff);
old_b_state = input_b(); //read portb before turning on int.
enable_interrupts(global);
printf("keypad test");
if (key_pressed) {
find_key();
output_d(0x0);
delay_ms(250);
output_d(0x2);
delay_ms(250);
_________________ compiler PCM version 4.064 |
Wayne_
Posted: Thu Nov 13, 2008 10:56 am |
I would start by changing this
void RB_isr(void) {
if (old_b_state != new_b_state) { <---- Not required as this interrupted due to a change in state!
key_pressed = TRUE;
change to
void RB_isr(void) {
if (old_b_state == 0xFF)
key_pressed = true;
You don't actually use the push code ?
I can't see what your problem is! |
shroder300
Posted: Thu Nov 13, 2008 11:09 am |
Right now I am only printing the codes to the serial port.
My problem is the keypad buttons have to be held down for at least half a second before the program prints a press code and then release code (once the button is released). If I don't hold down the button I only get a release code on the serial port.
The changes you suggested didn't change the results at all. _________________ compiler PCM version 4.064 |
Posted: Thu Nov 13, 2008 2:00 pm |
Look at this CCS example file on using push buttons with #int_rb:
Quote: | c:\program files\picc\examples\ex_pbutt.c |
It has an example of how to do the isr (for 'press' or 'release' but not both).
Your complaint about the requirement for a 500ms hold down time is
caused by the delays in your loop. Your program only tests the status
every 1/2 second. That's the update rate. |
Posted: Fri Nov 14, 2008 5:54 am |
thanks, I didnt think about that. should I be checking the status in the isr instead? |
shroder300
Posted: Fri Nov 14, 2008 10:21 am |
Here is my final code. the int routine will pick up both a press and a release. the main function will only print a press, however.
Code: | /*==============================================================================
Jason Berkhimer
keypad from all electronics. 4 col pins, 4 row pins and common. col and row
through interrupts. prints raw data from keypad to serial port and portd
#fuses NOWRT //
#byte porta = 0x05
#byte portb = 0x06
#byte portc = 0x07
#byte portd = 0x08
#byte porte = 0x09
#use fast_io(B)
#use fast_io(D)
char kchar;
#int_RB
void RB_isr(void) { // detects both press and release
if (new_b_state != old_b_state); // make sure state changed
key_pressed = TRUE;
old_b_state=new_b_state;
b_state = portb;
if (b_state != 0xff){ // only print on press
printf("-%X-",b_state);
output_d(b_state);
setup_adc(ADC_OFF);
setup_spi(FALSE);
delay_us(50); // wait for pullups to come on.
set_tris_b(0xff);
set_tris_d(0x00);
set_tris_c(0x00);
old_b_state = input_b(); // read portb before turning on int.
if (key_pressed) {
find_key();
