Why will this 12F683 program not run? Running on Microchip PIC kit1 and programmed with MPLAB v8.1. Programs on 12F675 chips seems to run fine but I can't get any 12F683 program to run. I have tried several different chips on two different PIC kit1's with same results. I'm sure I'm over looking something simple.
Compiler v4.076
Hardware PIC Kit1
MPLAB v8.1
#include <12F683.h>
#device adc=8
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES PUT //Power Up Timer
#FUSES NOFCMEN //Fail-safe clock monitor disabled
