Why will this 12F683 program not run?
Stuffed-Bit
PostPosted: Sat Sep 27, 2008 6:04 pm     Reply with quote
Why will this 12F683 program not run? Running on Microchip PIC kit1 and programmed with MPLAB v8.1. Programs on 12F675 chips seems to run fine but I can't get any 12F683 program to run. I have tried several different chips on two different PIC kit1's with same results. I'm sure I'm over looking something simple.
Compiler v4.076
Hardware PIC Kit1
MPLAB v8.1
#include <12F683.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES PUT                      //Power Up Timer
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#use delay(clock=8000000)
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   setup_oscillator(OSC_8MHZ);
 while(true){
  output_high(pin_a5);
  output_low(pin_a4);
  output_high(pin_a4);
  output_low(pin_a5);
PostPosted: Sat Sep 27, 2008 6:24 pm     Reply with quote
while(true){
output_low(pin_a4);
output_low(pin_a5);
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=36118
Stuffed-Bit
PostPosted: Sat Sep 27, 2008 6:46 pm     Reply with quote
PCM programmer wrote:
while(true){
output_low(pin_a4);
output_low(pin_a5);
See this thread:
Duh!!! I knew it was something simple! Guess I should have stuck a scope on that pin.
