BYTE and BOOLEAN variables |
Posted: Mon Sep 29, 2008 12:32 pm |
I'm just playing with the driver lcd.c that comes with PCWH and am struggling with a compiler error that refers to line 64 in lcd.c:
*** Error 91 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(6,7): Expression must be a constant or simple variable
*** Error 48 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(12,27): Expecting a (
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(28,29): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(29,30): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(31,32): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(33,34): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(34,35): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(35,36): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(37,40): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(40,41): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(42,43): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(43,44): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(45,46): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(46,47): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(47,48): Expecting a declaration
*** Error 12 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 82(29,30): Undefined identifier set_tris_d
*** Error 12 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 94(30,31): Undefined identifier set_tris_d
*** Error 12 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 124(28,29): Undefined identifier set_tris_d
*** Error 12 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 135(24,39): Undefined identifier LCD_INIT_STRING
19 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Mon Sep 29 19:12:59 2008
The first problem line (64) is:
BYTE const LCD_INIT_STRING[4] = {0x20 | lcd_type << 2, 0xc, 1, 6};
What is BYTE supposed to be, a 'CCS' variable? I'm quite new to this so apologies if I'm being a retard.
Andy |
Posted: Mon Sep 29, 2008 12:50 pm |
Post a very short test program that demonstrates the problem.
It should have the #include for the PIC's .H file, #fuses statement,
#use delay() statement, and the #include for the lcd.c file. It should
have a main(). |
FvM
Posted: Mon Sep 29, 2008 12:56 pm |
The respective exampled as EX_LCDKB.C compiles without error. You can also see that BYTE is type alias for int8, defined in any 18Fxxx.h device file. These kind of error showers are often caused by a single simple syntax error. |
peaps
Joined: 15 Sep 2008 Posts: 11 Location: Hemel Hempstead, Hertfordshire, UK
Posted: Mon Sep 29, 2008 1:03 pm |
Thanks for the quick replies..
The code I am using (attempting to get lcd.c to work) is:
Code: | #include <16f819.h>
#use delay(clock=1000000)
#include <lcd.c>
#fuses INTRC_IO, NOWDT, NOPUT, NOMCLR, NOBROWNOUT, NOCPD
#bit LED = 5.1
void main(void) {
// set_tris_a(0b00000000);
setup_oscillator(OSC_1MHZ);
setup_ccp1(CCP_OFF);
setup_adc(ADC_OFF);
setup_adc_ports(NO_ANALOGS);
LED = 1;
LED = 0;
while(1==1) {
LED = 1;
lcd_putc("\f12345678");
lcd_putc("\f********\n--------");
delay_ms(250);
And lcd.c is pretty vanilla:
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#if defined use_portb_lcd
#locate lcd = getenv("sfr:PORTB") // This puts the entire structure over the port
#define set_tris_lcd(x) set_tris_b(x)
#else
#locate lcd = getenv("sfr:PORTD") // This puts the entire structure over the port
#define set_tris_lcd(x) set_tris_d(x)
#endif
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
BYTE low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
peaps
Posted: Mon Sep 29, 2008 1:15 pm |
Hmm. I have just added the line:
Code: | #define use_portb_lcd TRUE |
And now it compiles. Is it falling over on the line that says:
Code: | #locate lcd = getenv("sfr:PORTD") |
because PORTD doesn't exist on a 16F819?
If so, why did it tell me the error was on line 64? |
