BYTE and BOOLEAN variables
PostPosted: Mon Sep 29, 2008 12:32 pm     Reply with quote
I'm just playing with the driver lcd.c that comes with PCWH and am struggling with a compiler error that refers to line 64 in lcd.c:
*** Error 91 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(6,7): Expression must be a constant or simple variable
*** Error 48 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(12,27): Expecting a (
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(28,29): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(29,30): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(31,32): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(33,34): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(34,35): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(35,36): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(37,40): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(40,41): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(42,43): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(43,44): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(45,46): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(46,47): Expecting a declaration
*** Error 43 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 66(47,48): Expecting a declaration
*** Error 12 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 82(29,30): Undefined identifier set_tris_d
*** Error 12 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 94(30,31): Undefined identifier set_tris_d
*** Error 12 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 124(28,29): Undefined identifier set_tris_d
*** Error 12 "C:\PROGRA~1\PICC\drivers\lcd.c" Line 135(24,39): Undefined identifier LCD_INIT_STRING
19 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Mon Sep 29 19:12:59 2008
The first problem line (64) is:
BYTE const LCD_INIT_STRING[4] = {0x20 | lcd_type << 2, 0xc, 1, 6};
What is BYTE supposed to be, a 'CCS' variable? I'm quite new to this so apologies if I'm being a retard.
Andy
PostPosted: Mon Sep 29, 2008 12:50 pm     Reply with quote
Post a very short test program that demonstrates the problem.
It should have the #include for the PIC's .H file, #fuses statement,
#use delay() statement, and the #include for the lcd.c file. It should
have a main().
PostPosted: Mon Sep 29, 2008 12:56 pm     Reply with quote
The respective exampled as EX_LCDKB.C compiles without error. You can also see that BYTE is type alias for int8, defined in any 18Fxxx.h device file. These kind of error showers are often caused by a single simple syntax error.
peaps
PostPosted: Mon Sep 29, 2008 1:03 pm     Reply with quote
Thanks for the quick replies..
The code I am using (attempting to get lcd.c to work) is:
#include <16f819.h>
#use delay(clock=1000000)
#include <lcd.c>
#fuses INTRC_IO, NOWDT, NOPUT, NOMCLR, NOBROWNOUT, NOCPD
#bit LED = 5.1
void main(void) {
//   set_tris_a(0b00000000);
   setup_oscillator(OSC_1MHZ);
   setup_ccp1(CCP_OFF);
   setup_adc(ADC_OFF);
   setup_adc_ports(NO_ANALOGS);
   LED = 1;
   LED = 0;
   lcd_init();
   while(1==1) {
      LED = 1;
      lcd_putc("\f12345678");
      lcd_putc("\f********\n--------");
      delay_ms(250);
And lcd.c is pretty vanilla:
struct lcd_pin_map {                 // This structure is overlayed
           BOOLEAN enable;           // on to an I/O port to gain
           BOOLEAN rs;               // access to the LCD pins.
           BOOLEAN rw;               // The bits are allocated from
           BOOLEAN unused;           // low order up.  ENABLE will
           int     data : 4;         // be pin B0.
        } lcd;
#if defined use_portb_lcd
   #locate lcd = getenv("sfr:PORTB")    // This puts the entire structure over the port
   #define set_tris_lcd(x) set_tris_b(x)
#else
   #locate lcd = getenv("sfr:PORTD")    // This puts the entire structure over the port
   #define set_tris_lcd(x) set_tris_d(x)
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
      BYTE low,high;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init() {
    BYTE i;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE address;
   if(y!=1)
     address=lcd_line_two;
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( BYTE x, BYTE y) {
   char value;
    lcd_gotoxy(x,y);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd.rs=1;
    value = lcd_read_byte();
    lcd.rs=0;
    return(value);
peaps
PostPosted: Mon Sep 29, 2008 1:15 pm     Reply with quote
Hmm. I have just added the line:
#define use_portb_lcd TRUE
And now it compiles. Is it falling over on the line that says:
because PORTD doesn't exist on a 16F819?
If so, why did it tell me the error was on line 64?
