jaska
I2C difference 4.014 -->4.032--> |
Posted: Sat Aug 30, 2008 3:22 am |
I have code, working very well in 4.014.
After updating dont work.
What is changed?
I use PIC18F458.
I have already programmed memory, program cant read anything from
memory.... Maybe dont write too...
Jaska
Code: | #ifndef EEPROM_SDA
#define EEPROM_SDA PIN_B1
#define EEPROM_SCL PIN_B0
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS LONG int
#define EEPROM_SIZE 65535
void init_ext_eeprom()
output_float(EEPROM_SCL);
output_float(EEPROM_SDA);
void write_ext_eeprom(long int address, BYTE data)
short int status;
i2c_start ();
i2c_write (0xa0);
i2c_write (address>>8);
i2c_write (address);
i2c_write (data);
i2c_stop ();
i2c_start ();
status = i2c_write (0xa0);
WHILE (status == 1)
i2c_start ();
BYTE read_ext_eeprom(long int address)
BYTE data;
i2c_start ();
i2c_write (0xa0);
i2c_start ();
i2c_write (0xa1);
data = i2c_read (0);
i2c_stop ();
return (data);
Posted: Sat Aug 30, 2008 12:02 pm |
Post a test program that calls these functions. See the example code
below. The program below has the following output:
Code: | #include <18F452.H>
#use delay(clock = 4000000)
#include <24256.c>
printf("Start\n\r");
init_ext_eeprom();
// Erase the first two bytes/
write_ext_eeprom(0, 0xFF);
write_ext_eeprom(1, 0xFF);
// Read them. They should be 0xFF.
printf("%X ", read_ext_eeprom(0));
printf("%X", read_ext_eeprom(1));
printf("\n\r");
// Write 0x55 and 0xAA to the first two bytes.
write_ext_eeprom(0, 0x55);
write_ext_eeprom(1, 0xAA);
// Read and display the first two bytes.
printf("\n\r");
