I2C difference 4.014 -->4.032-->
jaska
PostPosted: Sat Aug 30, 2008 3:22 am     Reply with quote
I have code, working very well in 4.014.
After updating dont work.
What is changed?
I use PIC18F458.
I have already programmed memory, program cant read anything from
memory.... Maybe dont write too...
Jaska
#ifndef EEPROM_SDA
#define EEPROM_SDA PIN_B1
#define EEPROM_SCL PIN_B0
#endif
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS LONG int
#define EEPROM_SIZE   65535
void init_ext_eeprom()
   output_float(EEPROM_SCL);
   output_float(EEPROM_SDA);
void write_ext_eeprom(long int address, BYTE data)
   short int status;
   i2c_start ();
   i2c_write (0xa0);
   i2c_write (address>>8);
   i2c_write (address);
   i2c_write (data);
   i2c_stop ();
   i2c_start ();
   status = i2c_write (0xa0);
   WHILE (status == 1)
      i2c_start ();
BYTE read_ext_eeprom(long int address)
   BYTE data;
   i2c_start ();
   i2c_write (0xa0);
   i2c_start ();
   i2c_write (0xa1);
   data = i2c_read (0);
   i2c_stop ();
   return (data);
PostPosted: Sat Aug 30, 2008 12:02 pm     Reply with quote
Post a test program that calls these functions. See the example code
below. The program below has the following output:
Start
FF FF
55 AA
#include <18F452.H>
#use delay(clock = 4000000)
#include <24256.c>
printf("Start\n\r");
init_ext_eeprom();
// Erase the first two bytes/
write_ext_eeprom(0, 0xFF);
write_ext_eeprom(1, 0xFF);
// Read them. They should be 0xFF.
printf("%X  ", read_ext_eeprom(0));
printf("%X", read_ext_eeprom(1));
printf("\n\r");
// Write 0x55 and 0xAA to the first two bytes.
write_ext_eeprom(0, 0x55);
write_ext_eeprom(1, 0xAA);
// Read and display the first two bytes.
printf("\n\r");
