kender
Function pointer comparison. Bug in v4.071? |
Posted: Fri Jun 27, 2008 12:01 am |
Colleagues,
It’s great that v4 supports function pointers. However, it doesn’t seem to support the function pointer comparison at the moment.
typedef int8 (*fp)(int8, int8); // typedef for our function pointer
int8 do_it(int8 ix, int8 iy)
return (ix + iy);
// more functions that fit the fp typedef
fpFoo = &do_it; // initialize the function pointer.
if (fpFoo == &do_it) // during compilation, this line generates ERROR 48: Expecting a (
- Nick _________________ Read the label, before opening a can of worms.
Posted: Fri Jun 27, 2008 2:05 am |
The function name itself, _is_ the function's address. You don't need the '&' when referring to it.
Use a cast for comparisons. Given that fpFoo, is the address of a function, it expects to receive two variables. So:
return (ix + iy);
fp fpFoo;
fpFoo = do_it; // initialize the function pointer.
if ((int16)fpFoo == (int16)do_it)
