Problem with struct fields with pointers |
Posted: Thu Jun 19, 2008 2:13 pm |
I am trying to write a driver for the CAN module for the dsPic30F6012A (because there is no support for it that I am aware of). I am using PCD version 4.068.
I have unions/structs defined for the registers of the CAN module like this:
Code: | typedef union {
struct {
int1 void0:1;//bit0 read as 0
int ICODE:3;//Interrupt Flag code bits
int void4:1;//bit4 read as 0
int OPMODE:3;//Operation mode bits
int REQOP:3;//Request operation mode
int CANCKS:1;//CAN Master Clock select
int ABAT:1;//Abort all pending transmissions bit
int CSIDL:1;//Stop in idle mode bit
int void14:1;
int CANCAP:1;//CAN message receive capture enable bit
int16 Word;
}CiCTRL;
CiCTRL C1CTRL;
#word C1CTRL = 0x0390 |
I then try to access the register via a pointer as follows for example...
Code: | CiCTRL * ctrl;
ctrl = &C1CTRL;
ctrl->CANCAP = 1; |
This does not work. trying to modify CANCAP by using C1CTRL.CANCAP = 1 works just fine.
Looking at the assembled code from the list file, it is obvious that it will not work.
Code: | .................... ctrl->CANCAP = 1;
004F2: MOV #1,W0
004F4: ADD 8CE,W0 //8CE is the address of the pointer 'ctrl' I think
004F6: MOV W0,W5
004F8: MOV #FFFF,W0
004FA: AND 57
004FC: SL W5,#E,W0
004FE: AND #3FF,W0
00500: IOR 57 |
nowhere in that assembled code does it even try to do any form of indirect addressing, which would be necessary to modify data from a pointer.
It should be able to just do something like this:
Code: | MOV 8CE,W0
BSET [W0],#F |
if I try to access a different field, perhaps one that is not just one bit:
Code: | int16 op;
op = 2;
ctrl->REQOP = op; |
Code: | .................... ctrl->REQOP = op;
00582: MOV #1,W0
00584: ADD 8CE,W0 //Add 1 to ctrl pointer, OK, now at upper byte of C1CTRL word
00586: MOV W0,W5
00588: MOV #FFF8,W0 //OK, clears the 3 bits associated with REQOP
0058A: AND.B W0L,[W5],[W5] //preparing to write in the new value...
0058C: MOV.B 8D0,W0L //move 'op' to W0L
0058E: AND.B #F8,W0L //clears the 3 bits I need for REQOP?? this should be AND.B #07,W0L
00590: IOR.B W0L, [W5],[W5] |
The problem with this is that it ands the 'op' value with #F8, when it should be ANDing it with the inverse of #F8 (Actually even if it did, that this code would still not functionally work because of the nature of this control register, but that is besides the point).
If I try to change REQOP directly by doing
ctrl->REQOP = 2;
that works fine.
Also doing ctrl->CANCAP vs. (*ctrl).CANCAP makes no difference
One more example: (*ctrl).Word |= 0x8000;
Code: | .................... (*ctrl).Word |=0x8000;
0054C: MOV 8CE,W0 //put pointer address in W0
0054E: MOV W0,W5 //move W0 to W5...?
00550: ADD W5,#0,W5 //add 0 to W5....??
00552: MOV W5,W6 //.....move W5 to W6......?
00554: MOV #8000,W0 //OK, put 0x8000 in W0
00556: IOR W0, [W6],W0 //OR 0x8000 with [W6] this is good...
00558: SUB.B W6L,#2,W6L //subtract 2 from my pointer address....why?
0055A: MOV.B W6L,[W6] //put the low byte of the pointer address in the pointer location???
0055C: MOV.B #0,W0L //put 0 in W0L
0055E: MOV.B W0L,[W6+#0]//put W0L (0) in [W6]?? what? |
I have stepped through with the debugger while observing the RAM and this definitely does not work.
Has anyone else had any problems using pointers with structs/unions?
Is this actually a compiler problem or am I just doing something stupid? |
Posted: Thu Jun 19, 2008 3:11 pm |
What happens if you simplify the declarations without using typedef?. I have had problems at times with typedef, and pointers, and feel it is safer to run without it, especially for pointer operations. So:
union Cictrl {
struct {
int void0:1;//bit0 read as 0
int void14:1;
int16 Word;
}C1CTRL;
//As a comment, use _either_ int1, or a bit field, not both
union Cictrl C1CTRL;
union Cictrl *ctrl;
ctrl = &C1CTRL;
ctrl->fields.CANCAP = 1;
I'd quite expect it to be a compiler problem.
Does it change if you use *, rather than -> to access the element?.
So:
(*ctrl).CANCAP=1;
Even on the more mature versions of the compiler, operations wit pointers and typedef, sometimes go completely potty, s I'm not at all surprised f the 'D' version is even worse here.... :-(
Try giving the structure a name. The 'anonymous' form you are using, is a relatively recent addition to the compiler's (supposed) abilities, and I'd not be surprised if this caused problems. So:
typedef union {
struct {
int void14:1;
} fields;
int16 Word;
}CiCTRL;
CiCTRL C1CTRL;
CiCTRL * ctrl;
ctrl = &C1CTRL;
You may well find this forces the compiler to understand what is wanted.
kemp05jeff
Posted: Thu Jun 19, 2008 3:28 pm |
Thanks for your reply,
I have tried this:
Code: | union CiCTRL{
struct {
int void14:1;
}Fields ;
int16 Word;
union CiCTRL C1CTRL;
union CiCTRL *ctrl
ctrl->Fields.CANCAP = 1; |
this generates:
Code: | .................... ctrl->Fields.CANCAP = 1;
0049A: MOV #1,W0
0049C: ADD 8CE,W0
0049E: MOV W0,W5
004A0: MOV #FFFF,W0
004A2: AND 57
004A4: SL W5,#E,W0
004A6: AND #3FF,W0
004A8: IOR 57 |
which Is exactly the same as before.
Here is (*ctrl).Fields.CANCAP = 1:
Code: | .................... (*ctrl).Fields.CANCAP = 1;
004CA: MOV 8CE,W0
004CC: MOV W0,W5
004CE: ADD W5,#1,W5
004D0: MOV W5,W6
004D2: MOV #FFFF,W0
004D4: AND 77
004D6: SL W6,#E,W0
004D8: AND #3FF,W0
004DA: IOR 77 |
It is slightly different, but just as wrong... |
Posted: Fri Jun 20, 2008 2:02 am |
You still have the int1 and field width definitions, used together, which is not really 'legal'. However I doubt if this is the problem.
You need to make an error report to CCS.
